Thread: aircon problem
  1. aircon problem
    Sep 2013
    stoke on trent U.K.
    Hi I am new to the forum so hope I can get some help with my 2003 a8 air con problem........Aircon did not work when I bought the car, had it regassed, no difference..so took to local garage who are pretty good, he put on Vag-Com for free(result)........it showed the following faults............
    00819 high pressure sensor...open circuit
    00727 potentiometer in defrost flap motor
    00728 left centre vent motor [COLOR=blue !important][COLOR=blue !important]position [COLOR=blue !important]sensor[/COLOR][/COLOR][/COLOR]
    00735 recirculation flap motor position sensor
    01851 position sensor defrost/upper body shut off flap motor
    08169 left rear cold/warm air outlet motor position sensor
    01592 sensor air quality
    Now the garage checked and found that the condenser had a bad [COLOR=blue !important][COLOR=blue !important]leak[/COLOR][/COLOR], so this is being replaced, as is the high pressure switch, before I start scratching my head and possibly ripping the interior apart for nothing, can anybody tell me is it possible all [COLOR=blue !important][COLOR=blue !important]the [COLOR=blue !important]motor[/COLOR][/COLOR][/COLOR]/sensor faults have one cause or do I really have so many faulty....if the latter is the answer where are they located and how do I access them. thank Ken
  2. Re: aircon problem
    Nov 2009
    46 Post(s)
    Welcome to VWAF
    Did he clear the faults, and the rescan?
    Could you get the full log off him which will show time and dates when the faults occured?
  3. Re: aircon problem
    Sep 2013
    stoke on trent U.K.
    Hi Chris
    Yes the mechanic did clear faults and all was well until I switched the heater/aircon controls on, then all faults reappeared on the rescan, I may try to get a full print out, however the garage boss has now returned from holiday and he is not so generous as the mechanic(if you know what I mean).But if this will help you to help me then I will bite the bullet and book the car in. Thanks Ken
    By the way does my first question show weird additions saying "blue, important, etc" in the middle of some sentences or is it my computer ??????
  4. Re: aircon problem
    Sep 2011
    Lurking over a keyboard ...
    Hi Pugboy607,
    Welcome to VWAF! ...
    VAG Error Code: 00727 Fault Location: Defroster Flap Motor - Position Sensor (G135)
    VAG Error Code: 00728 Fault Location: Left Center Vent Motor - Position Sensor (G136)
    VAG Error Code: 00735 Fault Location: Recirculation Flap Position Sensor (G143).
    VAG Error Code: 01851 Fault Location: Signal valve actuator motor and defroster vent front right (G317)
    VAG Error Code: 01592 Fault Location: air pollution Sensor (G238)
    Some of those are on here Link:- http://dtcsearch.planetvag.com/
    Did try a quick search to find something on 08169 but no hits in program/web ...
    In Chris's signature is a location map of VCDS users, which are forum members. If you get a scan done by one close to you for a beer token it will probably have better info in it.
  5. Re: aircon problem
    Sep 2013
    stoke on trent U.K.
    Hi Gupsterg
    Thanks for that, looking at the info it would seem that most, if not all of the problems are with motors and/or sensors attached to them. I took cabin air filter off to check its condition, found someone had marked the position of the flaps (I suspect to see if they move) I checked they dont !, I want to check at least one of the motor/sensors. So question, where are they located and more importantly how do I get at them ?
    Thanks Ken
  6. Re: aircon problem
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    VAG Error Code: 00819
    Fault Location:
    High Pressure Sensor (G65) - Open Circuit or Short Circuit to Earth
    Possible Cause:
    Wiring/Connector(s) from/to High Pressure Sensor (G65) faulty.
    Possible Solutions:
    Check Wiring/Connector(s) from/to High Pressure Sensor (G65).
    Check High Pressure Sensor (G65).
    Fault Location:
    Possible Cause:
    Fault Location:
    Possible Cause:
    VAG Error Code:
    00735
    Fault Location:
    Recirculation Flap Position Sensor (G143). If this code is found on late model VR6 (AAA) Refer to Code #01247.
    Possible Cause:
    VAG Error Code: 01247
    Fault Location:
    Evaporative Emission (EVAP) Canister purge Valve (N80)
    Possible Cause:
    Wiring/Connector(s).
    Fuse.
    Evaporative emission (EVAP) canister purge valve (N80).
    Fault Location:
    Position Sensor Defrost/Upper Body Shut-Off Motor: Right Front (G317)
    VAQ Error Code: 01592
    Fault Location:
    Air Quality Sensor (G238) - Open Circuit or Short Circuit to Positive.
    Possible Cause:
    Possible Solutions:
    Air Quality Sensor (G238) faulty.
    As taken from my
    EOBD II Error Codes
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  7. Re: aircon problem
    Sep 2013
    stoke on trent U.K.
    Hi keithUK
    Thanks for your reply, at the moment work is on hold for a couple of weeks as I am waiting arrival of new condenser, as well as new high pressure switch and air quality sensor, the latter two at such silly money I could not refuse them. I intend to fit all three, have the system regassed and then see what faults are still present (if any).........knowing Audi there will be !!! Watch this space
    Regards Ken
  1. aircon problem
    By masterinengland in forum Touran - Sharan - Caravelle
    Last Post: 10-10-2013, 09:44 PM
  2. Another Aircon problem
    By BeaBea in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-07-2013, 07:30 PM
  3. Aircon problem!
    By kromal1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-03-2011, 04:51 PM
  4. aircon problem
    By audistormer in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-04-2009, 07:18 PM
  5. Question A4 B7 aircon problem
    By richcyp in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-04-2009, 01:34 PM
