Thread: Seat Leon 1.8 20v fault code
  1. Seat Leon 1.8 20v fault code
    Dec 2012
    Yorkshire
    Hi all hope someone out there can help me my seat Leon 1.8 20v engine management light came on and the fault code reads bank 1 lean p0171 can any one tell me wot that means and wot I have to do to sort problem thanks
  2. Re: Seat Leon 1.8 20v fault code
    108 Post(s)
    1816 Post(s)
    Which year and engine code?
    16555 (P0171) - Fuel Trim; Bank 1: System Too Lean
    Possible Causes
    Mass Air Flow Sensor (G70) defective
    Intake System Leak(s)
    Possible Solutions
    Check Mass Air Flow Sensor (G70)
    Check Fuel Pressure Regulation
    Check Fuel Pump
    Check Injectors
    Check Intake System for Leaks
    Check Exhaust System for Leaks
    Check Secondary Air System for Leaks
    Check Vacuum Pipes for Leaks
  3. Re: Seat Leon 1.8 20v fault code
    Dec 2012
    Yorkshire
    Quote Originally Posted by Batunball View Post
    Thanks for reply it on a 02 plate code fault code is p0171
  4. Re: Seat Leon 1.8 20v fault code
    108 Post(s)
    1816 Post(s)
    Engine code, not the fault code...e.g. AGN
  1. Please Help seat toledo 1.9tdi 2006 reg fault code p0237
    By jimmcl in forum Toledo
    Last Post: 28-01-2013, 09:37 PM
  2. Please Help Seat Belt Pretensioner Fault Code
    By taff111 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-09-2010, 03:33 PM
  3. Please Help seat leon 1.8 20v idle and power problem
    By retrosleeper in forum Leon
    Last Post: 18-09-2010, 09:16 PM
  4. seat leon fault code 16947 system voltage too high?
    By yas_b in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 30-03-2010, 11:37 PM
  5. engine fault on a seat leon
    By merc2001 in forum Leon
    Last Post: 25-02-2010, 11:32 PM
