Thread: rear washer not working
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
  1. Re: rear washer not working
    #21
    Sep 2008
    6 Post(s)
    To access washer pump strip out the passenger wheel liner. Held in place with stainless steel torx screws. However before doing that - try disconnecting water pipe at driver's side in boot (above access hatch). If water comes out here, (get someone to assist) then you know blockage is further ahead at wiper motor.
    2016 BMW i3 REx (25k)
    2012 A4 Allroad Quattro 2.0 TDI (55k)
    2003 A2 1.4 TDI SE (166k) sold
    2001 B5 A4 2.5 TDI Avant Quattro Sport, (173k), sold
    1995 B4 80 1.9 TDI Avant SE, (175k), sold
  2. Re: rear washer not working
    #22
    Jan 2011
    derby UK
    Thanks. Will try disconnecting pipe at driver's side boot first. Is it at the top of bottom of the hatch? I've got speaker and amp in there. Quick inspection could not find anything. It is hard to get fingers in there because of the speaker and plastics around it. It is Avant sport model. Don't think I've seen the same setup in SE model.
  3. Re: rear washer not working
    #23
    Dec 2009
    southampton uk
    Quote Originally Posted by Google44 View Post
    This isnt easy.I had to dry this area out when the pipe split in the loom to the top of the hatch.I would look at the pump first cos it should be coming out of the fronts
  4. Re: rear washer not working
    #24
    Jan 2011
    derby UK
    Quote Originally Posted by mikeybutch View Post
    I agree, should look elsewhere first. Not sure how to get to pump tho. How about driver side footwell? Is there a connection point there too which can be easy accessed and disconnected? Dont know hot to get to motor nor how it operates the rear and front wipers. Perhaps someone can describe it here.
  5. Re: rear washer not working
    #25
    Dec 2009
    southampton uk
    There s/b a connector under the passenger side if its the same as aB5 cos thats what gave up on mine.Hope thats not gone on yours cos it took days to dry that out in summer!!Never accessed a pump but it shouldnt be too hard to remove the liner.
  6. Re: rear washer not working
    #26
    Jan 2011
    derby UK
    mine is not wet anywhere. Strange that it goes on passenger side then ends up on the right side in boot. is it close to pillar running along the door ?
  7. Re: rear washer not working
    #27
    Dec 2009
    southampton uk
    The problem is that you wont see the wet until you lift the carpet .I looked there cos I could hear the water coming out from that area when the pump ran.
  8. Re: rear washer not working
    #28
    Jan 2011
    derby UK
    true, however mine is spraying on front windscreen what should be going to rear. Hence dont think it leaks anywhere
  9. Re: rear washer not working
    #29
    Dec 2009
    southampton uk
    Ageed i continue to say its a pump issue
  10. Re: rear washer not working
    #30
    Sep 2008
    6 Post(s)
    No idea how much the pump is from Audi. You could possibly get a replacement from a breaker yard. Strip out the wheel arch to refit.
  1. Polo Rear Washer Not Working
    By cameraman in forum Polo - Derby - Lupo - Fox
    Last Post: 08-10-2015, 12:16 PM
  2. Please Help Rear wiper and washer not working
    By harriesh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-07-2011, 09:53 PM
  3. How To Fix that rear window washer that's not working...
    By Sly in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 14-03-2011, 03:30 PM
  4. Rear window washer not working
    By lozsale1 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-08-2010, 05:08 PM
  5. rear washer not working
    By maje in forum Octavia
    Last Post: 25-02-2010, 09:53 PM
