Thread: A6 C6 rear screen defroster not working
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
  1. A6 C6 rear screen defroster not working
    Aug 2012
    Birmingham
    Hi ,
    The switch seems to work with the orange LED going on , then off after 10 mins or so.
    But it has no effect on defrosting the rear screen.
    Does anyone know where the fuse for this should be ? Could it still be the fuse blown , even if the orange LED on the switch still comes on ?
    Thanks in advance.
  2. Re: A6 C6 rear screen defroster not working
    Sep 2008
    I would say have a look at the fuses or if there is any dirt spoiling the connection.
    This is easily rectified by wiping it clean. Replacing a dud fuse is also very easy.
    R
  3. A6 C6 rear screen defroster not working
    Aug 2012
    Birmingham
    Ok thanks , any idea where the fuse for it would be ?
  4. Re: A6 C6 rear screen defroster not working
    Sep 2008
    Driver side near the door panel you can pop open a small plastic bit.
    Heres a video - Interior Fuse Box Location: 2005-2010 Audi A6 - 2008 Audi A6 3.2L V6
  5. A6 C6 rear screen defroster not working
    Aug 2012
    Birmingham
    Thanks for the video.
    I have looked in the owners manual and I can't find a specific fuse for 'heated rear window'.
    There are 'auxiliary heating' fuses.
    I think I might need to get a dealer to have a look at it.
  6. Re: A6 C6 rear screen defroster not working
    Sep 2011
    Lurking over a keyboard ...
    It could be the wiring has broken away from the tab on the heater element within the windscreen...
  7. A6 C6 rear screen defroster not working
    46 Post(s)
    Get a fault code scan
  8. A6 C6 rear screen defroster not working
    Aug 2012
    Birmingham
    Ok can you recommend someone local to Erdington who can do a scan ?
    If its a tab connection that's come loose, would that be easy to fix ?
  9. Re: A6 C6 rear screen defroster not working
    Sep 2011
    Quote Originally Posted by Pbro View Post
    In below photo... the red box... it will be similar to that... the wire could have popped off... but like Chris say scan be handy....
  10. A6 C6 rear screen defroster not working
    Aug 2012
    Birmingham
    Quote Originally Posted by gupsterg View Post
    I see but Is that image from an Avant ? I have a saloon, presumably something would need stripping down to have a look.
  1. Rear Screen Demister not working.
    By dilun in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-02-2011, 10:31 PM
  2. Rear Wiper Screen Wash Not Working
    By Stuart_B in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-01-2011, 04:46 PM
  3. Rear screen wash not working.
    By zcar in forum Alhambra
    Last Post: 26-04-2010, 08:11 PM
  4. Heated rear screen not working help!
    By donbizzle in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 01-12-2009, 10:02 AM
  5. Avant rear screen demister not working
    By AndrewS1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-10-2008, 03:19 PM
