Thread: Audi 100 2.6 running problem
Results 1 to 9 of 9
  1. Audi 100 2.6 running problem
    Jul 2012
    London
    Hi. I have a problem with my 1993 Audi. When it's cold and when driving around town, when I take my foot off the throttle car is still going for about 3 seconds, but on motorway everything is fine. I checked for leaks around inlet manifold and vacuum system seems to be in order too. I just have no idea what it can be. Maybe someone can help me with that? Thanks in advance.
  2. Re: Audi 100 2.6 running problem
    Oct 2012
    uk - york
    HI, could be a sticky throttle cable,might pay to squirt some WD 40 (other makes are available) around the throttle body etc.
  3. Re: Audi 100 2.6 running problem
    Jul 2012
    London
    Quote Originally Posted by touranasurus View Post
    Thanks, will check. Another problem I forgot to mention was at some point when engine is cold rpm will jump between 1100rpm and 1200 rpm and then stop.
  4. Re: Audi 100 2.6 running problem
    Oct 2012
    uk - york
    Hi,might be worth putting some injector clean in the fuel, good luck.
  5. Re: Audi 100 2.6 running problem
    Gwent
    Have you had a flat or disconnected battery recently?
    see post#3 Audi 80 Quattro Estate 2.6 V6
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  6. Re: Audi 100 2.6 running problem
    Jul 2012
    London
    Quote Originally Posted by scotty33 View Post
    Well, could be. Car was just sitting for about 1.5 years without driving. So will definitely try reseting ECU! Thanks for this mate. I was about to order new idle vale, as I though that could be faulty... but will try this first, before spending money...
    EDIT: Can't find ECU/Ignition fuse, so don't hae anything to 'pull out'
  7. Re: Audi 100 2.6 running problem
    Gwent
    The ECU fuses are the big ones, I believe labelled 'moteur' just disconnecting the battery achieves the same thing.
  8. Re: Audi 100 2.6 running problem
    Jul 2012
    London
    I managed to reset ECU (removed negative pole for 20min) and it seems to be more 'sattled down'. RPM still jumps when changing gears, but considerably less. So I bought new idle valve, as mine has done loads, hope that will sort it out.
  9. Re: Audi 100 2.6 running problem
    Jul 2012
    London
    Quote Originally Posted by hunker7 View Post
    New idle valve didn't work, did check throttle position; fixed that, didn't work either. Will try to reset ECU and Throttle will see whether that works.
  1. Braking problem on Audi 100 s3
    By manji in forum 100 - 200 - Turbo - 100 S4
    Last Post: 28-12-2010, 07:03 PM
  2. audi 100 problem
    By robertwotton in forum 100 - 200 - Turbo - 100 S4
    Last Post: 13-04-2010, 09:04 PM
  3. Please Help Audi 100 2.3E Transmission Problem
    By yakub in forum 100 - 200 - Turbo - 100 S4
    Last Post: 29-07-2009, 12:37 AM
  4. Please Help Audi 100 2.8 V6 ABS Problem
    By hafizuddin in forum 100 - 200 - Turbo - 100 S4
    Last Post: 19-02-2009, 06:16 AM
  5. audi 100 idle problem
    By jessicasdad in forum 100 - 200 - Turbo - 100 S4
    Last Post: 19-09-2006, 11:36 AM
