Thread: A4 Front Brake Pads
  1. A4 Front Brake Pads
    Aug 2007
    I have replaced the rear pads before, using the wind back tool. I have never replaced the front pads and was wondering if anyone could offer any advice or warnings before I start, just so I know what I'm getting into. I didn't know about the wid back tool until I was in the middle of it, so if there's something tricky about the front pads, I'd love to know before I start.
    Any help is appreciated, thanks in advance.
    Mike
    1997 A4 Quattro
  2. Re: A4 Front Brake Pads
    Jul 2007
    yorkshire
    The front pads are much easier than rears, ive fitted them to mine disks and pads and the fronts done much quicker. just be careful with abs sensor wire.
  3. Re: A4 Front Brake Pads
    Feb 2007
    UK (London)
    Disclaimer: If you **** something up, not my fault. If you dont feel comfortable working on your car, then dont. Mechanics need to feed their children too.
    Replacing the front pads and rotors is pretty easy, and if you can turn a wrench you shouldnt have any problems.
    Tools needed:
    A large C-Clamp
    7mm hex
    19mm socket
    Pliers and a flat head screwdriver
    Whatever you use to get your car off the ground and take the wheels off.(jack/stands/etc)
    Nice to have but not needed:
    Syringe/something to catch the break fluid as it overflows.
    Liquid wrench
    Breaker bar/pipe.
    Bentley repair manual
    Materials:
    New Pads
    New Rotors
    New Guide Pins (optional) Part num: 321 615 141
    1. Jack up your car, and remove the front wheels. Make sure its secured on jack stands. You can do both at once, or one side at a time. Eitherway, do not use the OEM jack, as you may need to put your head below the rotor at certain times.
    2. If your car has brake wear sensors disconnect them first. Follow the wire from the brake pad to the harness (circled in red below). You will need to pry the little tab and turn it 90 degrees. Then lift the harness out of the bracket and disconnect it.
    3. Using a flathead and/or pliers remove the spring. (red arrows above)
    4. On the rear of the caliper there are two rubber caps, one near the top the other near the bottom. Take those off, and inside you will find a 7mm hex screw. Remove both of screws, and check their condition as they may need to be replaced. Sorry, no pics of that.
    At this point you should be able to take the caliper off, be careful not to rip anything. Once you get it off, secure it so that it does not fall to the ground. You can either support it on a jack stand, or tape it to the lower control arm, or anything else you see fit. If youre not replacing the rotors, skip down to step 7.
    5. Removing the caliper carrier: the carrier is attached using two 19mm bolts located in the back (circled in red below). These were a real pain in the *** to break. But after half a can of liquid wrench, a broken 19mm and extension they came off. When you remove these, the rotor should come off with out any effort, if it doesnt give it a few taps to loosen it.
    6. Install new rotors, and put the carrier back on. Tighten bolts to 92 ft
    lb.
    7. Replacing the pads: Pull out the old pads, the front one should just fall out, the rear is secured in place by a springed claw (see pic below), just pull it out.
    8. Now open your brake fulid reservoir cap as you will need to keep an eye on the fluid level. Using a C-Clamp, slowly push in the piston on the caliper until you feel resistance. If the brake fluid begins to over flow, remove some of it using the syringe. I didnt have any thing to catch the fluid with, so I just put some old rags around it to absorb it.
    9. Install the new pads in the same position as the old ones were located, place the caliper over the rotor and install the hex screws you removed in step 4. Tighten these to 18 ft lb. If you cant fit the new pads over the rotor, then you havent pushed the piston in all the way.
    10. Reinstall the rubber caps, put in the springs, and reconnect the brake wear sensors. Once you finish one side, pump the pedal a bit as that will drop the brake fluid level. Then do the other side. Once both sides are done, pump the brake pedal a few times again.
    11. Final step is to properly bed in your new brakes. Follow the instructions that came with your pads, or check the manufacturers website. The instructions for my pads (HAWK HPS) were as follows:
    a. After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
    b. Make an additional 2 to 3 hard stops from approximately 40 to 45 mph.
    DO NOT DRAG BRAKES!
    c. Allow 15 minutes for brake system to cool down.
    After step 4 your new pads are ready for use.
    Finished product:
    04 Audi A4 B6 1.8TQ S-Line 190bhp 6 Speed Duel SMIC
    Milltek Exhaust|VMR boost Gauge|SP51 K04-15 Outlaw (K04-23+)|Samco Sport DV|034 Sport CAT|
    To be fitted: B7 RS4 F-Brakes|B5 RS4 R-Brakes|SB Stage4| TT MAF| 380 inj|
  4. Thumbs up Re: A4 Front Brake Pads
    Aug 2007
    Thank you very much.That was more than I could have asked for. Very informative reply and I appreciate your help.
  5. Re: A4 Front Brake Pads
    Dec 2006
    Manchester
    Quote Originally Posted by docurley View Post
    Did you do that step by step guide????
    I'm sure i've seen it somewhere before, (or another similar one??)
    It's a good guide anyway, and should be posted in the "How To" section in my opinion.
    Nick
  6. Re: A4 Front Brake Pads
    Feb 2007
    UK (London)
    It's not mine it what I found some where else.
  1. W8 Front Discs and Pads
    By Dean 355 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-12-2007, 02:39 PM
  2. Brake pads
    By k3t4n in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-04-2007, 04:33 PM
  3. Front brake pads that never wear out!!
    By Matt B in forum Chat - Anything with wheels
    Last Post: 29-03-2007, 03:12 PM
  4. A6 Brake Pads
    By DWT in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-01-2007, 06:05 PM
  5. Fitting front Passat brake pads
    By ansumstan in forum Passat - Archive Topics
    Last Post: 04-12-2006, 12:30 AM
