Thread: audi a4 ajm upgrades
  1. audi a4 ajm upgrades
    Sep 2012
    ireland,tyrone
    i have a audi a4 b5 ajm i have a new turbo ordered which is a 150 bhp bora turbo and was just looking to know what would i need to hit the 160 bhp mark would the injecters be big enough for that sort of power etc and i was told that you can change injecter nozzles from a 2.5 tdi v6 audi/skoda which gives a big help
    thanks
  2. Re: audi a4 ajm upgrades
    1836 Post(s)
    The V6 is a VEP engine and the AJM is a PD, I can't see the nozzles being interchangeable. I would suggest you got hold of a set of ASZ/ARL 130/150 injectors. One point through, the turbo you have ordered must be some sort of hybrid as the 150 turbo is a transverse install with a built in manifold, yours is a longitudinal install with a separate manifold..
  3. Re: audi a4 ajm upgrades
    Sep 2012
    ireland,tyrone
    The V6 is a VEP engine and the AJM is a PD, I can't see the nozzles being interchangeable. I would suggest you got hold of a set of ASZ/ARL 130/150 injectors. One point through, the turbo you have ordered must be some sort of hybrid as the 150 turbo is a transverse install with a built in manifold, yours is a longitudinal install.
    thanks for the advice right i may look for different injecters yey the turbo i have a ordered is a 130 bhp turbo with a machined out front to make a 150 bhp bora wheel fit i have also bought the allard system which does away with the egr valve so that might give a help and i give the intake manifold a real good clean a person was telling me that you can buy injecter noozles of ebay?
    thanks crasher for your help
  4. Re: audi a4 ajm upgrades
    london/ UK
    Buy the whole set of injectors from a good working engine and make sure you have new seals to fit them in. It's not a straight forward procedure to fit the injectors correctly so i suggest you leave a pro do it. Your injectors are good enough for 160Bhp but you will need a good remap and expect the clutch to complain a bit !
  1. audi b5 ajm power loss
    By Duane Mckeever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-10-2012, 11:00 PM
  2. Audi A4 AJM TDi engine into my AJM MK4 Golf??
    By Digidick in forum Golf MK4 - 1999 - 2004
    Last Post: 26-03-2012, 11:34 AM
  3. Audi S4 Gearbox upgrades
    By spellmaster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-11-2009, 08:42 PM
  4. Audi A4 1.9TDi Injector Upgrades - Am Lost
    By diesel-a4 in forum Archive posts
    Last Post: 23-01-2008, 12:47 PM
  5. audi a4 chorus radio or speaker upgrades
    By andy5468 in forum Audi A4 - Archive Topics
    Last Post: 07-12-2007, 02:02 PM
