Thread: Audi A4 2.0 TDI DPF (B7) BRD – Uneven idle & smoking on idle
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
  1. Audi A4 2.0 TDI DPF (B7) BRD – Uneven idle & smoking on idle
    Sep 2012
    Oxford
    I have an Audi with idle smoking issues, the story so far
    Jan 12 – Recalled to Audi for injectors, 3 months later it starts to get uneven and slight smoking on idle.
    When the engine starts getting lumpy after starting the readings are as below, if I give it a good rev it clears for 30 seconds the cyl 4 comes right down to the same as the other cylinders but then goes back up with lumpy running. See readings below when lumpy.
    Group 13 Idle stabilization (Injector Quantity Deviation)
    -0.19 mg/str cyl 1
    -1.46 mg/str cyl 2
    -0.62 mg/str cyl 3
    2.28 mg/str cyl 4
    I swapped No.1 & No.4 injectors over, and the engine ran fine on idle with no smoke with the idle stabilization readings
    -0.09 mg/str cyl 1
    -0.28 mg/str cyl 2
    -0.68 mg/str cyl 3
    -0.29 mg/str cyl 4
    I took it out for a hours drive, parked it up for 2 hours and when started it was uneven and smoking again on tick over and the reading had swapped with the injector, see below,
    1.83 mg/str cyl 1
    -0.54 mg/str cyl 2
    -0.59 mg/str cyl 3
    -0.69 mg/str cyl 4
    So from here I fitted a new injector to No.1, started it up and it smokes like it’s never smoked before, thinking the wiring loom may have a fault I also fitted a new one too.
    It ‘s almost like the ECU wakes up in a different mood every time it’s started!
    Here's a snapshot today.
    Address 01: Engine (03G 906 018 AQ)
    08:25:39
    875 /min Engine Speed (G28)
    274.6 mg/str Exhaust Gas Recirculat. (actual)
    57.0°C Fuel Temperature (G81)
    27.0°C Intake Air Temperature (G72)
    280.9 mg/str Mass Air Flow (actual)
    1011.4 mbar Atmospheric Pressure
    -0.34 mg/str Injection Quantity Deviation Cyl. 1
    -0.12 mg/str Injection Quantity Deviation Cyl. 2
    0.47 mg/str Injection Quantity Deviation Cyl. 3
    -0.01 mg/str Injection Quantity Deviation Cyl. 4
    76.0°C Oil Temperature
    1013.9 mbar Boost Pressure (actual)
    Is the injector coded or need adapting? Any help on this would be greatly appreciated, please go easy on me if I missing something.
    Allan
  2. Re: Audi A4 2.0 TDI DPF (B7) BRD – Uneven idle & smoking on idle
    Sep 2012
    Oxford
    With new injector fitted
  3. Re: Audi A4 2.0 TDI DPF (B7) BRD – Uneven idle & smoking on idle
    Sep 2011
    Borders
    Mine had a similar problem last year, would smoke like that when Idling. I changed Fuel filter and injector wiring loom, Audi changed 3 injectors FOC and all seems to be ok now. When mine was fully warmed up it would idle fine and no smoke. Sure I felt it getting a bit lumpy again with the cold weather coming back though but have not noticed any smoke yet.
  4. Re: Audi A4 2.0 TDI DPF (B7) BRD – Uneven idle & smoking on idle
    Sep 2012
    Oxford
    Sorry to put to many posts, here is the car with the old injector put back in, still smoking but no where near as bad, stinks and burns your eyes though!
  5. Re: Audi A4 2.0 TDI DPF (B7) BRD – Uneven idle & smoking on idle
    Sep 2010
    Bedford
    HI A11an, Im really interested in this post as mine (A4 2.0TDi 140 06 plate) looks exactly like your first video on start up! I am just about at my wits end with it... i dont know if this just happend to be coincidence or not but ive noticed that water coolant level has dropped considerably prior to the smoking, fire it up and bingo beautiful white steamy smoke, just spent upwards of £1500 having the engine stripped down, block lifted and skimmed and pressure tested, saw some small markings from cyclinder 3, changed everything rebuilt. and bingo 250 miles later exactly the same as it was before....
    Have you managed to get anywhere with this.... any information would be greatly appreciated...
  6. Re: Audi A4 2.0 TDI DPF (B7) BRD – Uneven idle & smoking on idle
    Jun 2006
    UK, Mids
    Yes you need to code the injector in. The alphanumeric code is printed on the injector and individual for each one, it sepcifies the characteristics of each injector to the ECU as tested and calibrated in the factory.
    e.g. CKAUHWC
    Audi A8 - 2015 - 3.0TDI
  7. Re: Audi A4 2.0 TDI DPF (B7) BRD – Uneven idle & smoking on idle
    Mar 2012
    Lincoln, UK
    Im having the exact same issues with mine (same engine) it's had the injectors replaced under warranty before I purchased it in feb this this year (injectors done last August). I've been on the phone to audi uk and they've instructed me to book it back into audi in Lincoln and they will check the injectors again as from my symptoms it sounds like injector failure. It's in on thurs so ill keep you posted. It's got that smokey that we have to turn the car off at traffic lights, someone actually got out of their car the other day and told my mrs that there was a major problem with the car as their car was surrounded by smoke.
  8. Re: Audi A4 2.0 TDI DPF (B7) BRD – Uneven idle & smoking on idle
    Feb 2009
    Wakefield. W.Yorshire
    Hi, Any update on this?
    I've got a Passat Sport 170 BMR Engine, it has the exact same symptoms, smokes like crazy when idling stationary at lights etc..
    VW changed all 4 injectors, drives fine, apart from the odd misfire now and then..
    08 VW Passat 2.0 TDI 170 Sport (De-DPF'd - Remapped)
  9. Re: Audi A4 2.0 TDI DPF (B7) BRD – Uneven idle & smoking on idle
    Dec 2012
    St Austell
    Any more news as mine doing the same but Audi not intrested even thou they replaced the injectors under the lastest recall
  10. Re: Audi A4 2.0 TDI DPF (B7) BRD – Uneven idle & smoking on idle
    Jul 2008
    Stafford
    I had this for a year or so when the coolant temp is between 50 and 70 on the gauge on the dash, i.e. during warm-up. It can be really embarrasing in traffic.
    One day the car went in for a cambelt replacement and it has been perfect ever since. Don,t know why but it's good for me. The belt was done at the main dealer so maybe they did some tweaking but I suspect it is some kind of cam angle error that was naturally corrected when the belt was done.
    The injectors were replaced sometime later and so they are not in the equation.
    Good luck with yours.
    Patrick
  1. A6 3.0 TDi Smoking at Idle - Injector Failure?
    By BDriver in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-11-2012, 08:15 PM
  2. B5 Uneven idle speed issue
    By henry raison in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-10-2012, 08:44 AM
  3. Please Help A4 2.0 TDI 170 DPF Issues & Rough Idle
    By VAG in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-08-2012, 08:48 AM
  4. Please Help Audi a3 1.6 uneven idle and flatspot
    By jrm91 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 26-01-2010, 10:22 PM
  5. 2000 Bora TDI PD - uneven idle
    By Boraman in forum Bora - 1998 - 2005
    Last Post: 29-04-2007, 09:57 PM
