Thread: Second Hand A6
  1. Second Hand A6
    Oct 2012
    Moray, Scotland
    Hello, I have recently just sold my MK5 GTI and looking to get an A6 now! Needing something a good bit bigger! First post on here and was wondering if somone can give some advice on the two types I am looking at.
    I was going to get a 2.7 but heard that the gearbox's weren't near as reliable as the 3.0 tdis. I am pretty sure its the 3.0tdi I will get but have seen some 3.2fsi models which might intrest me.
    The 3.0 sline or lemans editions that I have been looking at are around 70-80K on the clock which I am certain will not be alot for a audi 3.0 tdi. Could someone advise on that to look out for on theses and if there are any faults I should be aware of?
    I have tried to do my research and have only come up with check if the autobox oil has been changed the the cam chain has been serviced. Is there anything else that could be an issue to look out for?
    Kevin
  2. Re: Second Hand A6
    mostly in the garage
    Hi Kevin, I guess there'll be lots of previous threads on the subject of buying.... try a search using something like "3.0l tdi advice" then have a browse through.
    On the cam chain issue, cam chains are not a service item so those engines that develop the rattle at start up, sometime accompanied by a fault code can only be fixed by engine removal to renew the chains.
  3. Re: Second Hand A6
    Nov 2009
    46 Post(s)
    Quote Originally Posted by c4a5er View Post
    You beat me to it!
  4. Re: Second Hand A6
    Aug 2012
    SOUTHAMPTON, HANTS, UK
    Quote Originally Posted by Kevin Walker View Post
    Kevin
    I've got 2.7 TDI Quattro with auto gearbox and was told by Audi that gearbox is sealed for life (no need to change oil ever).
    As about cam chain rattle - 130K on clocks and not single squeak (hit wood hard few times ).
    Also was told by unreliable source that with Audi you got to worry about Multitronic gearboxes not Tiptronic (which fitted to 2.7 and 3.0 models)
  5. Re: Second Hand A6
    Nov 2009
    46 Post(s)
    Quote Originally Posted by AN AUDI FAN View Post
    only fwd is fitted with multi - quattro is fitted with tiptronic
  6. Re: Second Hand A6
    Sep 2011
    Lurking over a keyboard ...
    Audi state sealed for life... for an enthusiast that does not apply
    Link 1:- audipages A8 Automatic Transmission Servicing
    Link 2:- Tiptronic ATF, transmission fluid change/flush - Articles
    Setup for gearbox in A6 is pretty similar to above links... from what I read somewhere the Tiptronic in the A6 was derived from one used in the A8...
    Link 3:- Tiptronic oil change !!
    I had tip oil changed when chain rattle fixed... most enthusiast seem to be getting it done from posts I've seen
    ZF are the manufacturer... I think in their data PDF's they recommend a change xxxxx miles
    If you do a google for ZF 6HP19 or Audi 09L there are plenty of PDF's with good data
  7. Re: Second Hand A6
    Aug 2012
    At least half of what he told me was true
  1. Question LEFT hand drive TO right hand drive headlight beam benders
    By A4 Lad in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-08-2014, 06:02 PM
  2. Second Hand Numbers
    By theskyfox in forum A1
    Last Post: 15-01-2012, 09:47 PM
  3. Question new or second hand
    By con1981 in forum Bora - 1998 - 2005
    Last Post: 27-08-2009, 07:24 PM
  4. Second hand A4
    By danredfern in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-11-2008, 10:52 PM
  5. help at hand
    By skinner in forum General Detailing/Cleaning Questions
    Last Post: 03-02-2008, 02:51 AM
