Thread: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 65
  1. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #21
    Norfolk
    Unclip top steering column cover by pushing up from the side. A plastic lever helps prevent damage. You will then see two torx screws, one each side. You have to turn steering wheel 180 degrees to get to each screw. Underside of bottom cover has another screw in hole in middle. Remove bottom cover copletely. Now you can disconnect the battery. Disconnect the battery with the ignition stil on, this keeps the steering lock in the unlocked position which may help later. Disconnect the electrical connections and pull the wiring awa from the column. Remove cover from steerining column/ rack (behind pedals and includes footrest) Remove steering rack pinion bolt and slide column up. Remove column bolts x4 and lower gently until you can unplug connector on steering lock. Now the whole thing will lift out. Getting steering lock off column is the next bit of fun. This is not a ten minute diy job. You will need a couple of hours at least for a first time attempt.
  2. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #22
    Nov 2012
    waterford ireland
    Quote Originally Posted by martin1810 View Post
    Martin, Thanks a million, very good detailed responce. I only went so far today and got worried about the airbag going off so put it back together. I'll give it a go later in the week and report back.
    Thanks again.
  3. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #23
    Nov 2012
    waterford ireland
    Hi Martin & V6Jules
    Did this job today without a problem thanks to your posts and advice guys. Thanks a million for posting this advice in the first place and then answering my questions. I cut a small nick in the green rubber cover on both microswitches to get in a bit of wd40 and work the switches in and out. I also glued a bit of plastic onto the little pusher lever that contacts the unlocked microswitch. I know this is not a permanent fix but if I got another year or so I would be happy. If it happens again I might try get a couple of switches and replace. (Id have to get someone else to do the soldering as I would'nt chance it)
    Thanks again
  4. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #24
    Sep 2008
    SE London
    WD40 is not contact cleaner. It's an oil-based solvent. Use either Servisol or Maplins own brand switch cleaner N62AN
  5. Smile Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #25
    Mar 2013
    Cheltenham
    Quote Originally Posted by reddevil7 View Post
    i would just like to add to this thread i had my car fixed 18 months ago at the cost of 150 quid they had the steering column off inside 20 mins did there magic on the workbench and car was ready to go after an hour top class fix they recently done my glowplugs as well they have the software to do all is required on everything vw i recommend these guys very highly so if you can get your car to northampton they will fix it they have had people come from as far away as ireland so if u need any more info drop me a line and i will pass on there mobile number all the very best fellow dubbers reddevil7
    I got same problem, please let me know contacts of these specialist northampton if you still have it.
    Thanks.
  6. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #26
    Sep 2010
    wellingborough uk
    hi Kenny I have sent you a private message with the guys mobile number they will sort you atb reddevil
    May 2014
    stoke on trent
    Hi I am having the same problem with my VW passat and would like to get in contact with the guys in Northampton to get fixed. If you could send me their number that would be great. Thanks
    Hi Kenny did you manage to get the passat fixed? Would you have contact details if so. Thanks
  8. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #28
    Sep 2008
    SE London
    If you’re anywhere near Northampton, many have used this firm to fix their steering lock problem:
    PASSAT B6 (3C)DIFFICULT START,steering lock.., | eBay
    For more details and further hints on this fault in a .doc format PM me an e-mail address and can attach by return
  9. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #29
    Sep 2010
    wellingborough uk
    hi Declan just got back from Majorca so I have just seen your message if you have not sorted it let me know and I will send you there mobile number atb redddevil7
  10. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #30
    Feb 2009
    Anybody on here ever had a problem once the microswitches have been changed over. When i first replaced my unit and tried to start car it was turning over but just came up with same fault. Now i cant even get the ignition to come on. However if i press the lower microswitch on the circuit board when its connected the car makes a horrible clicking noise etc.
    Can anybody advise as to why ive lost ignition totally?
  1. Steering Lock See Workshop and dealer problem
    By UkMark in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-02-2020, 08:30 PM
  2. Friendly Midland Dealer for key recode
    By Thacker in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-01-2011, 07:04 PM
  3. 2008 Audi A3 Wing mirror cheap fix anyone?
    By cunny678 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-01-2010, 02:15 PM
  4. 2003 abs & steering angle recode need help
    By deutsch in forum VCDS - General Questions
    Last Post: 28-11-2009, 12:34 AM
  5. Quattro rear ABS sensor cheap fix?
    By Strange Fish in forum New Member Introductions
    Last Post: 13-09-2008, 02:53 PM
