Thread: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 65
  1. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    Apr 2007
    France
    12 Post(s)
    Crasher, having completely hijacked this thread, let me just finish by saying that my letter to the CEO of VW in Germany regarding their policy on injector replacement was passed to VW France who said that it's not their policy to resolve problems that haven't occurred.
    The best bit was when I spoke to the manager of the service dept in my dealers a couple of years ago about reports on this forum of injector failures. His reply was that I shouldn't believe things I read on UK forums....
    1996 Laguna 2.2D
    1977 MGB roadster
  2. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    1840 Post(s)
    Quote Originally Posted by Quatrelle View Post
    Yes, I remember you relating that at the time and it made me smirk, the French just don't like us, its about time we realised that.
  3. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    Jan 2011
    Leighton Buzzard, UK
    Just a little update to say the fix I did nearly two years ago still seems to be working fine in my passat. Glad the photos are still helping people :-)
  4. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    Nov 2012
    coventry
    Hi Reddevil7 just had a quote from dealer for £805 FOR this problem can you post number or name of place in northampton you used. I am Coventry and should manage to get car to northampton. Need car for work so quite urgent.
  5. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    Norfolk
    Quote Originally Posted by tommo1961 View Post
    The quote is nonsense. Try another dealer. The part is £75.00 plus fitting and coding, should be less than £300 all in.
  6. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    Nov 2012
    waterford ireland
    Hi all.
    I'm new to the forum and joined because of V6Jules guide to fixing this dreaded steering lock problem. Fair play to ya V6Jules ;-). Anyway I am considering doing this procedure tomorrow, however one question before I start tearing the car appart. I have a B6 Passat, 1.6L Petrol.
    I am having difficulty starting the car. Sometimes it starts for a second or two and then cuts out, it could take 10 attempts or it might start first time. Other times it dosent even turn over but various attempts later it will start. However I have never gotten any error message on the console. Does indicate anything? Should there always be an error on the consule?
    Any help is much appriciated. Thanks in advance guys.
    P.S. If anyone is having any Alfa 156 probs give me a shout. Have loads of experience with these ;-)
  7. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #17
    Norfolk
    Why take car apart if you don't have diagnostics to show what the fault is. Steering fault and immobiliser fault should show up in a scan. How to fix the steering fault is explained on my site.
  8. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #18
    Nov 2012
    waterford ireland
    Quote Originally Posted by martin1810 View Post
    Thanks Martin
    Low and behold this morning I started the car and it displayed the dreaded “Steering Lock See Workshop” in the driver information system on the dash and the Steering Wheel warning light illuminates in either Red or Orange.
    Do you suggest I perform this operation now?
    Also is there any danger I could set off the airbags, should I disconnect the battery? Do all the covers around the steering column need to be removed? (I am having difficulty trying to figure out how to remove the steering column)
  9. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #19
    Norfolk
    Seems like steering lock needs replacing now. I still have a few spare switches if you want to try the repair method on my site.
    0 0 1
  10. Re: Cheap Fix for Passat B6 Steering lock problem with non dealer recode
    #20
    Nov 2012
    waterford ireland
    Thanks Martin. Think I try a bit of contact cleaner first.
    Is there any danger I could set off the airbags, should I disconnect the battery? Do all the covers around the steering column need to be removed? (I am having difficulty trying to figure out how to remove the steering column)
  1. Steering Lock See Workshop and dealer problem
    By UkMark in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-02-2020, 08:30 PM
  2. Friendly Midland Dealer for key recode
    By Thacker in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-01-2011, 07:04 PM
  3. 2008 Audi A3 Wing mirror cheap fix anyone?
    By cunny678 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-01-2010, 02:15 PM
  4. 2003 abs & steering angle recode need help
    By deutsch in forum VCDS - General Questions
    Last Post: 28-11-2009, 12:34 AM
  5. Quattro rear ABS sensor cheap fix?
    By Strange Fish in forum New Member Introductions
    Last Post: 13-09-2008, 02:53 PM
