Thread: Both rear doors stuck shut.
  1. Both rear doors stuck shut.
    Oct 2005
    I received the following as a PM - I'd rather everyone learned and/or assisted so I'm placing the trimmed down version here.
    Quote Originally Posted by duzz
    hi can any kind person help,both rear doors are stuck shut. i have tried banging door with no luck,the knobs do come up when the inside lever is pulled but still will not open. now cannot drive with grandchild.
    Untill last week offside was only working when i repeat lock,lock,lock......untill there was a clunk,then it would unlock
    2002 vw passat130 tdi sport est. any input would be great.
    not all that keen on paying too much because in good faith paid lots for the car,has the millage is low for year again
    i have tried banging the door,still no joy
  2. Re: Both rear doors stuck shut.
    Gwent
    I had the same thing, luckily I do not 'need' to use the back seats, I did persevere with the banging on the doorskin, by the lock, I was able to open the one door, then the other started opening normally a few weeks later.
    I guess the banging trick works only when you bang at the same instant that the current is flowing. With that in mind I suggest trying this: lay a piece of protective carpet or rubber against the door, then a piece of wood. Use something like a SDS drill set on hammer only to rattle the area while you operate the locks.
    There are 2 methods for getting the door open yourself, get the doorcard and window reg plate off, then obliterate the lock with SDS drill/chisel. The other is to drill a hole in the inner doorskin in an appropriate place, to get a torx bit on the deadlock part of the lock, remove same and the door can be unlocked. Both methods have been detailed in this forum, try a search.
    I also know there was a write up about repairing the faulty deadlock armature/contacts. maybe by 'Caldirun' ?
    Checking the wiring plugs within the gaiters would also be high on my list - when you get the doors open..
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Both rear doors stuck shut.
    S Wales - no, not save the whales!
    Aren't these, by reputation, prone to a bit of 'physical stiffness'.
    If you do get them open, I'd try getting some WD40 right into the mechanism before going for the electrical fiddling.
    Can't do any harm, can it?
    2004 Passat Estate 1.9 TDI SE 130
  4. Re: Both rear doors stuck shut.
    Gwent
    I'm not so sure about 'physical stiffness' (oo er), what's been described is consistant with deadlocks failing to operate, it seems to be an electrical issue, Though a regular lube might avert the issue in the first place...
  1. Cannot shut both passenger side doors!
    By WillPassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-01-2010, 07:54 PM
  2. Please Help Rear Door Stuck Shut Please help.
    By OilyKnight in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-12-2009, 07:29 PM
  3. Question glovebox stuck shut
    By zetectdci in forum Polo - Derby - Lupo - Fox
    Last Post: 03-02-2009, 10:10 PM
  4. Please Help Mk 4 rear door stuck shut
    By giggsy07 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-12-2008, 12:40 PM
  5. Stuck shut rear door (Child Lock problem)
    By kevin123 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-06-2007, 01:51 PM
