Thread: Saetbelt Warning Chimes with belt on!
Results 1 to 10 of 10
  1. Thumbs up Saetbelt Warning Chimes with belt on!
    Sep 2012
    Houston, Tx, USA
    I have a 2010 CC 140bhp. I have enjoyed the car, but these annoying seatbelt chimes stated at random this June/July in the hot Texas summer. After multiple visits to the dealer, (who could find no warning codes showing) and browsing this forum, I traced the seat belt sensor wires to a handy little flap cover by carpet at front left under the driver seat. A handy connector is there which was simple to disconnect (push the small plastic catch away from the connector and pull gently). This solved the problem - no more random dings and no waning lights showing from other systems! Peace and quiet.
    I always wear a seat belt and although this solution may seem drastic, it looked like a practical solution to me as the dealer said it would be ~ $370 to pull out the seat and fit a new seat belt buckle assembly, which he was not even sure at the time would solve the problem.
    Happy driving and hope this helps anyone with the same issue.Seat Buckle Sensor.jpg
    ps the wires on the CC are yellow and blue for the seat belt buckle and the connector black - the pic is a little out of focus.
  2. Re: Saetbelt Warning Chimes with belt on!
    Manchester
    Hi Colin my golfs doin the same. I have 2 clips on mine. What colour were your cables? I am thinking the ones in the yellow clip are for the air bag in the seat??
    Mk6 Golf 2009 Deep Black Pearl 2.0 GTTDI 140, Vancouvers
  3. Re: Saetbelt Warning Chimes with belt on!
    Apr 2011
    derbyshire uk
    hi colin
    same problem with my 2006 a3 sportback. real pita.
    i have been quoted £80.00 for the new catch.
    does anyone out there know if its ok to replace the catch with the ignition off, ie. will i get any unwanted warning lights showing on dash afterward
    cheers ian
  4. Re: Saetbelt Warning Chimes with belt on!
    Manchester
    Hi Ian,
    I found on my Golf that there was a 2pin Plug (thats the one) and a 3pin plug (yellow not the one). If you unplug the 2 pin plug there will be no problem. If you unplug the 3 pin plug, then the air bag light will come on and there is no way of turning it off. I had to go to a garage and get it turned off by computer.
    With the 2 pin plug disconnected the seat will come out and then the unit can be exchanged. I however have left mine disconnected. Not that i am advocating not wearing a seat belt of course - its a force of habit for me to put mine on when i get in the car. Hope this helps
  5. Re: Saetbelt Warning Chimes with belt on!
    Apr 2011
    derbyshire uk
    thanks for the advice paul.
    still deciding whether to change the catch or not.
    might try just disconnecting as you have suggested
    thanks
    Quote Originally Posted by paul.mgrath View Post
    Hi Ian,
  6. Re: Saetbelt Warning Chimes with belt on!
    Manchester
    Hi ian
    gave you a bit of a bum steer. You can't take the seat out without removing the airbag plug. When I did this I got the airbag warning. Suggest disconnecting the 2pin plug only and leaving it at that. Sorry for any confusion caused.
  7. Re: Saetbelt Warning Chimes with belt on!
    Apr 2011
    derbyshire uk
    no problem paul. just disconnected for now
    thanks
    Hi ian
  8. Re: Saetbelt Warning Chimes with belt on!
    Aug 2007
    New Romney Kent
    You can also use VCDS to code out the seatbelt warnings.
    VCDS HEX-NET registered owner (Covers all VAG cars)
    PM me if you require scans or adaptations doing in S.E. Kent, can unlock SFD.
    Audi TTS 8S
    VW ID.3 Tour
  9. Re: Saetbelt Warning Chimes with belt on!
    Apr 2011
    derbyshire uk
    cheers gizmo
    Quote Originally Posted by Gizmo68 View Post
  10. Re: Saetbelt Warning Chimes with belt on!
    Jan 2013
    dewsbury
    should not get air bag warning when disconnecting if you leave the keys out of the ignition and replace plug before turning ignition on
  1. Seat Belt Warning
    By Brian566 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-01-2013, 11:36 AM
  2. Coolant warning chimes
    By barrheadbear in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-08-2011, 06:29 PM
  3. Chimes / beeps at ignition + diagnostics
    By JM-LANCS in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-06-2009, 07:50 PM
  4. Constant warning chimes
    By Steve_A in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-09-2008, 10:23 PM
  5. Seat belt warning
    By KeithS in forum Golf MK5 - 2004 - 2009
    Last Post: 05-09-2008, 02:56 PM
