Thread: Expensive to fix? 005491 - Left Engine Mount Solenoid Valve (N144): Open Circuit
  1. Expensive to fix? 005491 - Left Engine Mount Solenoid Valve (N144): Open Circuit
    Feb 2011
    Winchester
    Hello friends,
    I have a 160K mile A6 C6 2.7 Tdi which is fantastic in every respect but it's getting on in terms of mileage.
    I have the standard Swirl flap problems (will do something about it one day, did everybody see the re-manufactured units on eBay for £180 a side?) and some minor parking sensor problems but this one has just started to appear over the summer.
    Well, you'll see it's only happened the once but I also saw it in June and cleared the fault.
    I have done a bit of googling and it seem to be related to the hydro mechanical engine mounts that the car can tighten up when you give it the beans. If it's engine mounts then it sounds like a nightmare to get to and pull off for checking / cleaning. Is there anybody out there that has done the job?
    P1573 - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 251234 km
    Time Indication: 0
    Date: 2012.07.16
    Time: 17:34:23 Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Voltage: 12.01 V
    Bin. Bits: 1
    Bin. Bits: 1
    Bin. Bits: 1
    Thanks, Rob
  2. Re: Expensive to fix? 005491 - Left Engine Mount Solenoid Valve (N144): Open Circuit
    Feb 2010
    Cambridge
    I have the same fault on my car and was told it was approx £100 to fix. They also told me it won't cause any problems so most people ignore it.
    A6 3.0 TDI Le Mans
  3. Re: Expensive to fix? 005491 - Left Engine Mount Solenoid Valve (N144): Open Circuit
    Dec 2011
    Swindon
    9 Post(s)
    In vcds. How do you scan this, what is the measuring block sequence ?
  1. Question Engine mount solenoid code 17996
    By allymac in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-05-2017, 08:00 PM
  2. Help: Fault code IMRC- Inlet Manifold Runner circuit, open circuit.
    By OliB in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 04-12-2010, 11:47 AM
  3. engine mount solenoid valves
    By kangtdi in forum VCDS - General Questions
    Last Post: 09-12-2009, 05:20 AM
  4. engine mount solenoid nalve
    By coupe2 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-09-2008, 07:25 AM
  5. Golf mk 3 rear left engine mount change
    By spainy in forum Golf MK3 - 1993 - 1999
    Last Post: 11-05-2008, 04:11 PM
