Thread: Audi A4 1.9tdi lack of turbo boost
  1. Question Audi A4 1.9tdi lack of turbo boost
    Jun 2006
    I have a 1998 A4 1.9tdi and the turbo seems not to be working at present. The Airmass flow meter was replaced a few years ago and this fault has happened before (15months ago), lasted for about a week, then rectified itself. Basically the car power is very flat but otherwise goes ok. the only other clue is that when the engine is hot and you restart it, you get the revs flying up to 2500-3000 revs before dropping back down to idle, and a plume of diesel out the back. I have spoken to audi and they are clueless.
    Can anyone advise on the course of action? Hopefully without costing thousands!
    Jun 2006
    Same here
    May 2006
    This could be the turbo oil seal, allowing oil to build up in the turbo, that acts like fuel when you re-start causing the engine racing.
    El Dingo
    Jun 2006
    I've since had the car on the audi computer and the faults were the wastegate controller and the fuel shutoff valve.
    May 2006
    Glad you got it fixed.
    El Dingo
    Jun 2006
    Not fixed yet. Waiting for parts. Will let you know if the problem is sorted.
  7. Talking
    Jun 2006
    Inlet manifold change over valve and fule cut off valves replaced and car seems as good as new. Total cost £90: £50 to put it on computer and £40 for the fuel valve. Manifold valve was free gift from Bath Audi garage
    Anyone got any experience of chipping turbo diesels? I'd like to up the HP to 110 from 90.
  1. Audi A6 Avant 1.9tdi 130pd turbo not working
    By barney2 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-03-2013, 12:04 AM
  2. Lack of power from my 1.9TDI Passat
    By andyccna in forum New Member Introductions
    Last Post: 11-12-2010, 10:27 AM
  3. Audi A4 1.9TDI 100bhp TURBO CHARGER NEEDED!!!
    By cha3 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-06-2007, 11:41 PM
  4. A4 TDI 2.5 V6 - underpowered / lack of boost
    By Griswald in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-03-2007, 05:15 PM
  5. Audi A4 1.9tdi lack of turbo boost
    By DRCDG in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-06-2006, 11:11 AM
