Thread: Sharan 1996 1.9TDI AFN blown turbo
  1. Sharan 1996 1.9TDI AFN blown turbo
    cmb1960 Guest
    Got a whole 6 miles into my holiday and the turbo blew. New experience for me - very dramatic! For those who have yet to experience such a moment, the engine runs at full revs, black smoke pumps out the exhaust (big time) and removing the key or even the battery has no effect at all. Turns out that if you don't stall the engine before the sump oil (that's what it's using for fuel) runs out, it's bye bye engine/car too. Hopefully your missus won't grab the dog and run away without even so much of a "save yourself" as mine did!
    Anyway - anyone had this happen who can advise me please? I stopped the engine while there was still some oil in the sump (near bottom of dipstick). No horrible mechanical sounds before it stopped (apart from the noise as it was running so hard). I guess the cat will be foobarred but other than that do you think it's worth investing in a replacement turbo? She is a 1996/7 1.9TDI CL with AFN engine (is that 110BHP?) has 147K miles, little rust and a known history so I'm loathe to scrap her if avoidable. But I don't want to spend loads of time and money if the engine is likely to be shot either.
    How easy is it to swap a turbo? From what I can see it's pretty hard to get at on axle stands?
    Any help would be appreciated!
  2. Re: Sharan 1996 1.9TDI AFN blown turbo
    Aug 2011
    Meath
    You might be able to do some of the work from the top, it's not the easiest job in the world but its doable at home. You could get the turbo refurbished or get an exchange unit. A specialist VAG breaker would also be a source. I checked fleabay, new ones for £299.00 New item should have 12 months guarantee item number 200568459232
  3. Re: Sharan 1996 1.9TDI AFN blown turbo
    london/ UK
    You need to check the compression as it hydro locks and rods bend usually ! Any more vibrations than before when the engine is running will spell disaster and the rod will go trough the block in max 1000 miles or so !
  4. Re: Sharan 1996 1.9TDI AFN blown turbo
    cmb1960 Guest
    Thanks both. adamss24 - how do I safely turn the engine over with the blown turbo and ensure it doesn't kick into life when testing the compression. Sorry to be thick about this but am much more familiar with petrol than diesel
  5. Re: Sharan 1996 1.9TDI AFN blown turbo
    london/ UK
    You need to take glow plugs off so you can turn the engine by hand first + you need to drain the intercooler of oil otherwise the engine will runaway again ! If you disconnect the main plug from the injector pump then the engine won't fire. Also you can take off the positive feed from the stop solenoid on the VE pump,undo the tiny 8mm nut and remove the wire off the terminal...
  6. Re: Sharan 1996 1.9TDI AFN blown turbo
    Pembrokeshire
    22 Post(s)
    i usually remove the boost pipe from the inlet manifold, then all it can breath is fresh air.
  1. Please Help 2002 Passat 1.9tdi turbo blown hose
    By nuttyworld in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-03-2011, 12:29 PM
  2. Freeing up Turbo Actuator - 1.9Tdi AFN
    By leighmagill in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-01-2011, 07:15 PM
  3. Please Help Turbo Failure 1.9tdi (AFN)
    By smiffy big nuts in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-03-2009, 06:37 PM
  4. Blown Turbo on AFN 1.9TDi engine?
    By justbretta in forum Archive posts
    Last Post: 18-12-2007, 04:56 PM
  5. Blown Turbo 2006 1.9tdi
    By hitachizx in forum Passat - Archive Topics
    Last Post: 14-09-2006, 08:03 PM
