Thread: Brake servo issue and possible linked boost issue
Results 1 to 10 of 10
  1. Brake servo issue and possible linked boost issue
    Jun 2012
    Louth
    Hi, I had an issue where the servo leaked at the metal and I had no servo after the third brake press. This is now resolved via expoxy on the metal leak. However, if the car is left for 30 mins after running, there is no residual servo assist on the brakes (pedal is rock hard) When I start the car in the morning the brakes are solid and take a few secs to liven up! Other that that, boost is intermittent. Perhaps they are linked?
  2. Re: Brake servo issue and possible linked boost issue
    west sussex
    If the brake servo is leaking I'd advise replacing it rather than trying to patch a leak up especially where brakes are concerned, it sounds to me like you've still got a leak in it.
  3. Re: Brake servo issue and possible linked boost issue
    Jun 2012
    Louth
    Thanks dan, i will try to isolate the servo with a mighty vac, and test it for a leak
  4. Re: Brake servo issue and possible linked boost issue
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Check the plastic servo hose also, as a crack would cause a leak too. Ans also check the off-takes from this hose.
    Alan.
    VW T6 150 DSG Camper £££
  5. Re: Brake servo issue and possible linked boost issue
    Jun 2012
    Louth
    I have used suds to check for leaks in the past, was thinking if this is safe now.....................?
  6. Re: Brake servo issue and possible linked boost issue
    Jul 2010
    Monmouth, Wales
    7 Post(s)
    Use suds by all means, but you won't see any bubbles, as you are looking for vacuum leaks, the bubbles will all be inside the pipes or components!! You will have to listen carefully for leaks. Maybe I missed it before, but what car is it? Petrol or diesel?
  7. Re: Brake servo issue and possible linked boost issue
    Jun 2012
    Louth
    b5 a4 tdi avant quattro, i used suds before to find the big hole in the servo, it made a noise as it was sucked in!
  8. Re: Brake servo issue and possible linked boost issue
    Aug 2011
    Meath
    This is a common problem with A4's and Passats. There are several write-ups available showing how to change the servo, this is a safety critical issue and the servo should be replaced. It's a couple of hours well spent replacing it. you don't want a rock hard pedal in an emergency.
  9. Re: Brake servo issue and possible linked boost issue
    Jun 2012
    Louth
    Assuming its the problem, will a passat one from the same era fit?
  10. Re: Brake servo issue and possible linked boost issue
    Aug 2011
    Meath
    As far as I know theyre the same. This problem has been talked about for years,the easy cure was a wire coat hanger when you did your weekly checks. The plenum chamber fills with water can't drain and rusts and rots the bottom of the servo. It's not too hard to change just a bit time consuming if you do change yours its a good opportunity to change your brake fluid.
  1. N75 Boost Valve Issue A6
    By bag320 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-10-2011, 01:33 PM
  2. Please Help A4 tdi 130 - found water in the brake servo - boost problems ?????
    By jak90 in forum Chat - Anything with wheels
    Last Post: 26-09-2011, 07:43 PM
  3. S4 Turbo boost issue
    By Skyblueads in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-01-2009, 04:45 PM
  4. Boost issue possibly resolved.
    By Ben in forum Chat - Anything with wheels
    Last Post: 04-02-2008, 09:03 PM
  5. Turbo/ Boost Issue ???
    By naz11 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-07-2007, 12:40 PM
