I'm new to the forum. Have just bought myself a 2002 Audi A4 B6 Avant 2.5Tdi. Great car but the cruise control (factory fitted) doesn't work (no matter what the speed etc). I've read various parts can cause the problem from the clutch and brake switches - increased revs changing gear and brake lights on continuously as indicators of each failure respectively - to the switches in the stalk itself and even dry solder joints in the control module. Mine has none of the gear/clutch switch fault symptoms.
So is there anyone in the Peterborough or South Lincs area have a VAGCOM they'd be kind enough to point in the direction of my car?
Many thanks
Ben
