Thread: vagcom 311.2
Results 1 to 10 of 18
  1. vagcom 311.2
    May 2009
    cornwall
    I've borrowed a laptop with vagcom 311.2 on it, shows as a registered copy, connect it to my a4 b6 and it talks to the car ok, can see some modules and I erased a few fault codes.
    Problem is I've installed rns-e and genuine audi bluetooth module, and I need to set some adaptations done, the rns-e works fine and it sees the bt module, but I can't register a phone to it, and the bluetooth logo doesn't show, the vagcom can't communicate with the radio or navigation modules, it talks to the mfsw and I can also talk to the clocks make needles move.
    Any ideas anyone, thought it may be a faulty cable but it obviously can talk to the car.
  2. Re: vagcom 311.2
    46 Post(s)
    311.2?
  3. Re: vagcom 311.2
    May 2009
    cornwall
  4. Re: vagcom 311.2
    46 Post(s)
    Quote Originally Posted by mogsy View Post
    never heard of 311.2 before hence my reply
    are you sure you have the version right?
  5. Re: vagcom 311.2
    May 2009
    cornwall
    Yes, Vagcom release 311.2-N lots of mentions of it on interweb, so appears to be legit
  6. Re: vagcom 311.2
    1840 Post(s)
    When 311 was current blue tooth had not even been invented, it is something like 12 years out of date! We are on 11.11.1 now!
  7. vagcom 311.2
    46 Post(s)
    LOL that's why I've never heard of it.
    FYI - were on 11.11.4
  8. Re: vagcom 311.2
    May 2009
    cornwall
    I live in Cornwall, things move more slowly down here!
    Should it still work though?
  9. Re: vagcom 311.2
    Norfolk
    It will work a bit with K- line which is found on pre-2005 VW's. Post 2005 vehicles use a mix of k-Line and CAN for communication. Audi were ahead of the game so the old K-line cable may not work after 2003 or even earlier. The last version of vag-com 311 was 401, so even your old version is out of date. It will never work on newer CAN vehicles and CAN was introduced quite early on for Infotainment so it won't work for what you want.
  10. Re: vagcom 311.2
    1840 Post(s)
    were on 11.11.4
    Me to, just checked.
  1. VAGcom how to
    By Peter_HMR in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-08-2010, 09:20 PM
  2. VCDS 908.2 / 311 vagcom, won't find #46 cent. conv on 2001 A6 tdi ... help!
    By jontawn in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-06-2010, 11:22 PM
  3. Replies: 1
    Last Post: 23-06-2010, 10:19 PM
  4. Vagcom
    By richy191 in forum VCDS - Help Requests
    Last Post: 21-11-2009, 01:25 PM
  5. Vag-Com 311.2 + Sharan 2005
    By emcu5 in forum VCDS - Help Requests
    Last Post: 19-01-2009, 05:40 PM
