Thread: a8 navigation dvd stopped mid journey
Results 1 to 10 of 11
  1. a8 navigation dvd stopped mid journey
    Sep 2012
    Bolton
    I have an A8 3.7 V8 2004 with the MMI 2G and the sat nav has been working perfectly well until yesterday, half way down the motorway it decided to stop showing the map. Now when i start the car it says check navigation cd, but the disc will not eject for me to then start from scratch and reinsert.
    The red lights flash but no disc ejects! Is it a new dvd player? if how much should i pay? Is it repairable? Thanks for any help.
  2. Re: a8 navigation dvd stopped mid journey
    46 Post(s)
    have you tried resetting your mmi - hold setup + central control knob + upper right inner key
    you might need your dvd drive unlocked to get the disc out then you could try a lens cleaner or a new disc.
  3. Re: a8 navigation dvd stopped mid journey
    Sep 2012
    Bolton
    Yes i have reset the MMI already but no joy. Is unlocking the dvd drive something I could do or is it a dealer job? Audi have quoted £140 just to look at it to do a diagnostic!!
  4. Re: a8 navigation dvd stopped mid journey
    Southern County Softy
    20 Post(s)
    look for a local member with VCDS to unlock the drive
    A4 2.5 tdi QS (mapped)
  5. Re: a8 navigation dvd stopped mid journey
    46 Post(s)
    A forum member can do this for you.
    Look VCDS - Users Locations and VWAF User Location Map - VCDS - Google Maps
    If you need anyones attention brought to this thread I can PM them on your behalf.
    I have moved this to the A8 section.
  6. Re: a8 navigation dvd stopped mid journey
    Sep 2012
    Bolton
    Thanks guys, all comments very much appreciated. Ill look at the VDCS link. Once again, thanks.
  7. Re: a8 navigation dvd stopped mid journey
    20 Post(s)
    once you get the disc out, run a lens cleaner through it and also clean the disc.
    1 1 0
  8. Re: a8 navigation dvd stopped mid journey
    Harrow, UK
    Apologies for hijacking the thread but I thought it would be appropriate to elaborate on a similar problem I have been experiencing. I too had DVD errors on my MMI navigation but was able to remove the disk for cleaning. I tried to clean the DVD with a cleaning disk but it wouldn't play as it did not recognise the disk as a 'navigation disk' so I got the following error: 'Insert Navigation Disk'. I have tried a new disk and am in the strange position of being able to enter addresses in the Navigation screen and it even calculates the route but all I get on the map screen is a black blank screen. I have 2 DVDs both have the same error. Re-setting MMI makes no difference and a VAGCOM test did not throw up an errors. An Audi dealer has quoted something ridiculous like £1200 for a replacement DVD drive but that's way too much and I'm not even sure if that's the problem.
    I hope OP has more luck than me, but does anyone have any ideas what might be going on? What type of DVD cleaner do you recommend as I can't get the one I have to even play?
    Thanks.
    Kamal
    A8 3.0L petrol Mulitronic, 2004 model
  9. Re: a8 navigation dvd stopped mid journey
    Sep 2009
    NW England
    Are you using a genuine Audi disc or a copy?
  10. Re: a8 navigation dvd stopped mid journey
    Harrow, UK
    Quote Originally Posted by Micha_elD View Post
    Good question. Initially was running a copy which the person who upgraded my MMI gave me about 2 years go. It's worked faultlessly until now. However, even when I use the original (but old) disk I get the same blank screen on the map page.
    Kamal
  1. DVD Navigation
    By sacha35 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-07-2010, 09:56 AM
  2. Help with Audi A4 navigation DVD
    By Monsieur in forum In Car Entertainment
    Last Post: 28-03-2010, 07:13 AM
  3. Turbo Failure Mid Journey
    By davyrob32 in forum Golf MK5 - 2004 - 2009
    Last Post: 23-05-2009, 07:59 PM
  4. Audi DVD Navigation plus
    By ezpixs in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-05-2008, 10:36 AM
  5. DVD Navigation Plus
    By BandAid in forum Audi A4 - Archive Topics
    Last Post: 25-04-2007, 05:38 PM
