Thread: Beetle brake conversion kits
  1. Post Beetle brake conversion kits
    Does anyone know is you can get just parts for brake conversion kits? Looking for a brake caliper only for a VW beetle drum to disc brake conversion kit but can't find a supplier. Whole new kit no problem, but not just a replacement brake caliper. Any help here appreciated.
  2. Re: Beetle brake conversion kits
    Jun 2007
    Gwent
    GSF have them:65605 for a pair, or 65606 single
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Beetle brake conversion kits
    Sorry, didn't give enough info. Rear brake caliper required. It has been fitted to a VW beetle framed trike and has an e-brake on it
  4. Re: Beetle brake conversion kits
    Jun 2007
    Gwent
    Aah right, I'm guessing here, but the calipers may be robbed from the VAG parts bin, are they Girling with 38 stamped on them? 38mm would be the piston diameter. What diameter and thickness is the disc?
    Golfs, passats, jettas, Audi 80, 100 etc all used the type of caliper you describe. Is the caliper you have faulty? maybe this link will be of some use?:http://www.20v.org/brakere.htm
    Usual problems are, handbrake mechanism seizes up, or sliding pins seize or dust boot becomes holed, and bore starts to rust.
  5. Re: Beetle brake conversion kits
    Thanks for that. Local motor factor could not match but thought they were Varga calipers. The disc diametre is 280 ml. Problem is that cowboys who fitted conversion to the trike have different calipers on each side, so it pulls to one side. Thats why we need to try to find the same caliper for the other side. Hitting a brick wall with getting just a caliper as it was a conversion kit. Everyone says we need to buy the complete kit again. (Complete it at over £400 by the way!)
  1. HID Kits
    By D'Squared in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-08-2007, 11:52 PM
  2. b7 kits for b6,
    By dub love in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-06-2007, 03:46 PM
  3. Brake conversion
    By scott-mk3 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-05-2007, 09:23 PM
  4. HID Light conversion Kits
    By netwave in forum Chat - Anything with wheels
    Last Post: 11-03-2007, 12:07 AM
