Thread: Help needed Fault code 18265/P1857
  1. Help needed Fault code 18265/P1857. NOW FIXED
    Jun 2006
    Cardiff
    I keep getting the traction control warning light coming on. It's been quite random, but has come on 4 times today twice when I've pressed the DIS button on the wiper arm? The car starts to shake slightly too?
    VCDS scan shows DTC 18265 Load Signal Error which comes up in the ABS module. No other fault codes!
    I've done the obvious google search on it & it seems to be a fairly common fault on some VAG cars. Seems to usually be caused by a broken wire on the Alternator sense cable that goes to the top of the gearbox.
    Tried to have a look & a feel round on the top of the gearbox & yes there is a cable going from the Alternator to the Gearbox, but it's difficult to see how it terminates on the Gearbox. Easy to see it on a transverse VAG car, but not so easy on the A4.
    Has anyone on here had this problem on an Audi.
    18265/P1857/006231 - Load Signal: Error Message from ECU
    Possible Symptoms
    • Malfunction Indicator Light (MIL) active
    Possible Causes
    • Fault Code(s) stored in Engine Control Unit (ECU)
    Possible Solutions
    • Check Engine Control Unit for Fault Code(s)
    B6 A4 Avant 1.9 TDI 130 Sport (6) Moro Blue, GMBH S Line Kit, Decatted, remapped to 165bhp, EGR delete, Goodyear Eagle F1 Asy's, Full Leather, Cruise Control, Bose, Audi phone prep, Cool Glove Box, Parking Sensors, Rear privacy glass.
    Seat Ibiza 1.2 TSI FR 3 door Lima Green.
  2. Re: Help needed Fault code 18265/P1857
    Jun 2006
    Cardiff
    It started throwing code 17669 too. So I replaced the injector harness yesterday, & just did a 300 mile trip today without issues.
  1. Dreaded ESP Warning after 10 mins driving. Fault Code 18265
    By Lbcvantage in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-04-2014, 04:47 PM
  2. vag.com fault code help needed??
    By sps in forum VCDS - General Questions
    Last Post: 15-11-2010, 10:11 AM
  3. interittent esp light fault codes 18265 and 00526
    By nickeym1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-02-2010, 10:28 PM
  4. VAG'n in the Wind / Fault Code P1857-35-10
    By rubberdubby.md in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-08-2009, 12:47 AM
  5. Code - P1857
    By stonedandhappy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-07-2008, 09:30 AM
