Thread: Jammed windows B5
  1. Exclamation Jammed windows B5
    Jun 2006
    Cheshire Gtr-Manchester
    All the windows in my 2001 estate 1.9tdi have stopped working -no up or down - fuses ok- relays at each motor clicking in when switch pressed (assuming the cam bus activates these relays - no corroded or broken wiring around the Comfort ECU
    Advice on where to check or look would be apprecated - thank you
    Jan 2006
    Nottingham
    Try locking the car with the key, holding the key in the lock position for a few seconds as this usually brings all the windows up.
    Jun 2006
    Thanks i have now tried this but no joy at present
  1. Jammed door lock
    By peegee in forum Touran - Sharan - Caravelle
    Last Post: 23-09-2010, 08:52 AM
  2. how to open jammed lock to fix it!
    By sensible in forum Chat - Anything with wheels
    Last Post: 23-09-2010, 08:50 AM
  3. A6 Drivers Door Lock Jammed?
    By MetalMan in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-07-2008, 02:49 PM
  4. The bonnet is jammed!!
    By kian in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-06-2007, 12:26 PM
  5. Electric window mechanism jammed TDI sport Passat 52 plate
    By Tony31 in forum Chat - Anything with wheels
    Last Post: 29-04-2007, 10:43 PM
