Thread: Intercooler Issues High Mileage
Results 1 to 9 of 9
  1. Exclamation Intercooler Issues High Mileage
    Aug 2008
    Hi Everyone,
    I have a 2006 S Line 2.0 TDI 170 which has 110k on the clock, recently heard a rattling sound which seemed to be coming from the passenger rear of the car after much inspection by myself, RAC & local garage found it to be the pipes and mount to my inter cooler.
    Been told i need the lot replacing!!!
    Anyway come across this problem before?
    Just would like so insight in whether i should spend the £500 to get it sorted or change it for something with less mileage.
    Hope any can share your thoughts or stories much appreciated.
    v11kal
  2. Re: Intercooler Issues High Mileage
    Sep 2011
    Melksham, Wiltshire, UK
    Hmmm....I was under the impression that the intercooler was located at the front of the car, in front of the radiator on the lock carrier (the crossmember incorporating the headlights and radiator grille).
    I would hold onto you money for the moment!
    The air inlet for the turbo charger (which is mounted at the rear of the engine) is ducted around the engine and into the bottom of the intercooler. The cooled air then exits at the top and is fed into the throttle housing. There is no pipework connected to the intercooler which goes anywhere near the rear of the car, so I would look elsewhere or your problem, IMHO.
    Can you describe the rattling you are experiencing? Does it occur when the car is stationary or moving? Is it a regular rattle or random? Does it occur over bumps only?
    1999 GTi Turbo - Turbo Technics uprated turbo, Forge charge cooler, Jabba remap, Milltek SS system, Brembo GT brakes, Koni Sportlines, Neuspeed ARBs
  3. Re: Intercooler Issues High Mileage
    Jan 2012
    Coding Something
    What exactly is wrong with the pipes/unit, expand on this please, with pics if possible.
  4. Re: Intercooler Issues High Mileage
    Aug 2008
    Hi, Yes you are correct the Intercooler is located at the front! However the rattling seemed to be coming from the rear of the car (thats what i was meant to say)
    Anyway, the rattling only happens over bumps and rough roads and the sound only occurs when the car is moving. The sound is like a metal rattling (two pieces of metal crashing against one another)
    Spoken to my mechanic who says that its weeping from around the intercooler & pipes but until they have stripped it down they will not know 100% becuase its quiet a tight area around the front end.
    Hope this is of some use!
  5. Re: Intercooler Issues High Mileage
    Jan 2012
    Coding Something
    Is it a sportback?
  6. Re: Intercooler Issues High Mileage
    Aug 2008
    3 door Hatchback
    Havent got any pics i am afriad because i wasnt with the car when it was on the ramp.
    The sound is very simular to the sound you may experience from a loose exhaust bracket.
  7. Re: Intercooler Issues High Mileage
    Jan 2012
    Coding Something
    Check under the rear wheel hubs for a flappy piece of plastic, this has caused issues for some but cant recall if 3dr had this fitted as only had clients with sb's with the issue.
  8. Re: Intercooler Issues High Mileage
    Sep 2011
    Yes, I concur with NHN. Don't know if is the same on the 3-dr but I had 'clunking' noises when I first got my Sportback (5-Dr). It used to drive me mad and then I read on the forum here about these plastic stoneguards which cause an issue. It is well documented here.
    I had the guards replaced at a cost of about £30. Never have had a problem since!
    I'll see if I can locate the thread.......
  9. Re: Intercooler Issues High Mileage
    Sep 2011
    Hi V11KAL....here you go....search for 'Clonking noise from rear of car'
    or go to this link=
  1. High Mileage?
    By The Polisher in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-08-2012, 04:30 PM
  2. Very high mileage A6
    By 2xboxerdogs in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-11-2010, 02:18 PM
  3. High Mileage
    By The Technician in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-11-2009, 04:22 PM
  4. High Mileage
    By tomb in forum Audi A3 - Archive Topics
    Last Post: 14-01-2009, 10:24 AM
  5. High Mileage A4
    By sparticus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-02-2007, 12:21 AM
