Thread: turbo actuator
  1. turbo actuator
    Feb 2012
    camelford cornwall
    just bought one of these for my a6 so thought i would share it as there quite rare to get hold of on there own so im told
    VW AUDI TURBO CHARGE ACTUATOR WASTEGATE FOR GARRETT /gt1749v 2.5 TDI V6 A4 A6 A8 | eBay
  2. Re: turbo actuator
    Nov 2008
    hi jst a quik q why would you buy on of these? the reason i ask my turbo had gone a couple of months ago and i had to have it recond.
    cheers
  3. Re: turbo actuator
    Feb 2012
    camelford cornwall
    b'coz my acuator has gone and is not holding vacuum
  4. Re: turbo actuator
    Up North
    Did a lot of research when I had turbo problems on my fondly missed 2.5 V6 TDI.
    The story was that the actuator adjustment threaded rod is supposed to be set up to the turbo on a flow rig so that you get the correct amount of boost (i.e. VNT position for a given engine speed) for a set actuator vacuum level.
    There were dark warnings of potential doom from the pundits. It might have been hogwash, but at the very least I'd do a measure and swap rather than just dive in.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  5. Re: turbo actuator
    1836 Post(s)
    They are hard to set up on the car, the adjustment is very fine and doing it on the car is hit and miss. I take the old one off and set the new one to the same measurement and so far I have had no problems.
  6. Re: turbo actuator
    Feb 2012
    camelford cornwall
    the old one had been messed about with so im going to have to find out what the preload should be and set it to that
  7. Re: turbo actuator
    Aug 2012
    Aberdeenshire
    I found this VNT TDI turbo: how to adjust actuator & cure boost problems while hunting around various forums for gen on my A4 AFB problems.
    The guy explains setting up the length really well
  1. Question Turbo actuator connector
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-06-2012, 03:02 PM
  2. Turbo wastegate actuator
    By josantos04 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-12-2009, 07:05 PM
  3. turbo actuator
    By mygolfygti in forum Golf MK4 - 1999 - 2004
    Last Post: 11-03-2009, 11:43 PM
  4. Question vnt turbo actuator rod
    By olds_kool in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2009, 11:25 AM
  5. Turbo actuator problem?
    By smohamm527 in forum Bora - 1998 - 2005
    Last Post: 30-01-2008, 02:29 AM
