Thread: 1.9tdi Quattro - Coolant loss and erratic intermittent temp fault
Results 1 to 10 of 26
  1. 1.9tdi Quattro - Coolant loss and erratic intermittent temp fault
    Nov 2008
    Really hope someone can help, 4 mechanics so far can't! My 52 1.9 tdi Quattro will drive fine but will sometimes alarm for coolant levels. Sometimes the temp stays at 90 then the alarm goes a off and all is fine. Other times the temp will clim to 115 or occasionally to 130.Of course I ease off when this happens. But then it goes back to 90 and stays there, again the coolant alarm goes off.
    When all this has happened, coolant levels have dropped, but no visible leaks. Tried radweld, found it on my driveway next day. The annoying thing is it never happens during idle and it's that random that mechanics have been out driving it but nothing happens.
    There is no sludge in oil filler cap and no hydrocarbons getting into the coolant, been tested. so not sure if it's the head gasket.
    My thoughts were just dodgy sensor but that doesn't explain loss of coolant. I was thinking maybe intermittent pump fault? Pump fails, temp rises, pressures rises and coolant dumps out of pressure release. Then pump kicks in and all goes back to normal, minus coolant? Just a thought but I have no idea. Anyone help?
  2. Re: 1.9tdi Quattro - Coolant loss and erratic intermittent temp fault
    chester
    17 Post(s)
    Sounds like the waterpump impeller hes de-bonded from the shaft,do a pressure test on the system to eliminate the head gasket though,this test wont show up a dodgy impeller just eliminate the H/G.
    A4 B6,A4B7Quattro,MK4 Golf,MK5Golf gone and well forgotten,MK6Golf.
  3. Re: 1.9tdi Quattro - Coolant loss and erratic intermittent temp fault
    1840 Post(s)
    Typical symptoms of PD head gasket failure.
  4. Re: 1.9tdi Quattro - Coolant loss and erratic intermittent temp fault
    Nov 2008
    Hi. Just spoke to a vw/Audi specialist. He said to check water pump by taking small header pipe off of coolant reservoir. It should be pumping. It isn't. If I put it below the level of the reservoir it flows like a tap but I assume this is siphon effect. Putting it on the reservoir stops anything coming out. Also, just drove the car temp was at 90 and all normal. Pulled over to have a look and coolant was coming out of the reservoirs overflow valve, although I had only filled it to minimum. There also seemed to be small air bubbles seeping into reservoir from main outflow pipe, don't know if that is significant or purely by air being sucked into system when restoring has run low.
  5. Re: 1.9tdi Quattro - Coolant loss and erratic intermittent temp fault
    Jun 2006
    Cardiff
    Sounds like your water pump impellor has failed. The small header tank pipe should flow into the header tank when held above it with the cap off. You should get a block dye test done too as you may have a blown head gasket aswell.
    Make sure you get the Radweld flushed out quick as it's really good at clogging radiators & heater matrix's up.
    B6 A4 Avant 1.9 TDI 130 Sport (6) Moro Blue, GMBH S Line Kit, Decatted, remapped to 165bhp, EGR delete, Goodyear Eagle F1 Asy's, Full Leather, Cruise Control, Bose, Audi phone prep, Cool Glove Box, Parking Sensors, Rear privacy glass.
    Seat Ibiza 1.2 TSI FR 3 door Lima Green.
  6. Re: 1.9tdi Quattro - Coolant loss and erratic intermittent temp fault
    1840 Post(s)
    I had a 1.9 TDI AVF engined A6 in yesterday with exactly the same symptoms and it has just had a new water pump fitted, 99% head gasket.
  1. Intermittent coolant gauge fault
    By RICHD962 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 12-08-2010, 09:45 PM
  2. 1.9TDI intermittent power loss
    By 832ark in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-10-2009, 09:12 AM
  3. erratic temp guage and "check coolant" light problem
    By Hurley1611 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-03-2009, 10:15 PM
  4. Coolant temp sensor fault?
    By Rolo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-03-2009, 10:42 PM
  5. A4 1.9TDI Intermittent power fault
    By Dave.jj in forum Audi A4 - Archive Topics
    Last Post: 13-02-2008, 04:19 PM
