Thread: Motor for Intake Manifold Flap (V157): Malfunction
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: Motor for Intake Manifold Flap (V157): Malfunction
    Sep 2008
    mostly in the garage
    agree on the motor but also check integrity of wiring...... air con performance suffers when the pollen filter needs changing???
    Apr 2011
    N/A
    This might sound silly, but how do you check the integrity of the wiring?
    I assume just a visual inspection as it is all enclosed in plastic covering!
    Im going to assume that the air con is a separate issue but a coincidence. It has struggled to keep the car cold these last few days. If you set it to 17* it blows on full whack constantly.
    May 2009
    swansea uk
    Look to see if the fuse it ok, it is on the same fuse as the air con fans. If it is gone disconnect the anti shudder valve wiring plug till you replace the part, or the fuse will blow again.
    Apr 2011
    N/A
    Quote Originally Posted by andrewgateway View Post
    Thanks.
    I have looked at the fuses and they all seems OK. There are two 'air con' related fuses in the drivers side fuse board and they both look good. I assume it would be one of them.
    It's all disconnected now an isn't being driven anywhere until fixed!
  5. Re: Motor for Intake Manifold Flap (V157): Malfunction
    Sep 2008
    There's no association between the engine fault and your air con issues. If the pollen filter is renewed and you still can't reduce cabin temperature enough then the system may need a service/re-gas.
    Apr 2011
    N/A
    I think I will change the pollen filter! I had it re-gased only a few weeks ago.
  7. Re: Motor for Intake Manifold Flap (V157): Malfunction
    #17
    Apr 2011
    N/A
    Just to pull this thread around in a nice big loop;
    I pulled the electronics from the throttle body which then produced a different error in Vag Com. This rested my mind that it was indeed faulty as opposed to just being thrown the wrong fault code.
    Bought a new part from EuroCarParts (Currently got 30% off)
    Fitted, cleared DTC's. And now its all good.
    The whole removal and refit process took about 40 minutes. Fairly easy to do.
    Thanks to everyone that helped here on the forum.
  8. Re: Motor for Intake Manifold Flap (V157): Malfunction
    #18
    Mar 2012
    glasgow
    i am having bother with this aswell,
    engine management light on then off then on and so on,
    got it checked and fault read intake flap motor faulty,
    i took it off the car and cleaned it and took off the cover as you have done in pic 2, it was soaked with used engine oil,(as yours is)
    is their meant to be oil in there?????????????, i would have thought it would short the electrics,
    i replaced it with one from ebay and car still shuddered at 1800 rpm, management light stayed on for a while then went out,
    100 miles later turbo blew, though i think this was a result of previous oil pump failure,
    any advice or help please,
  9. Re: Motor for Intake Manifold Flap (V157): Malfunction
    #19
    Apr 2018
    Swindon
    Resurrecting this as my car cut out and wont start and I get 012547 - Motor for Intake Manifold Flap (V157) - could this be the cause?
  10. Re: Motor for Intake Manifold Flap (V157): Malfunction
    #20
    Dec 2011
    Swindon
    9 Post(s)
    Did you change the part? I had issues with mine,changed it and no problems now
  1. Drivers side intake manifold flap motor
    By amjid in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 08-09-2012, 05:14 PM
  2. Intake Manifold Flap (V157)
    By SebastianTDI140 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-06-2010, 08:07 PM
  3. Please Help Golf Mark 5 Motor for Intake Manifold Flap
    By techi in forum Golf MK5 - 2004 - 2009
    Last Post: 09-05-2010, 01:14 PM
  4. Motor for intake manifold flap
    By stephen k in forum Golf MK4 - 1999 - 2004
    Last Post: 31-05-2009, 05:47 PM
  5. Motor Intake Manifold Flap
    By daveaustin in forum Archive posts
    Last Post: 06-12-2007, 04:39 PM
