Thread: Autosmart Tardis or Autoglym Tar remover?
Results 1 to 10 of 15
  1. Autosmart Tardis or Autoglym Tar remover?
    May 2010
    Glasgow
    Hey - i haven't de-tarred a car in a good few years and certainly haven't done my fairly new Audi but the bodywork is starting to get a little rough and covered in little specks of tar so I thought it will need some tar remover and then a clay bar set about it.
    I'm wondering if Tardis is safe enough for the bodywork if I use with caution or am I better off sticking with the Autoglym product? The last thing I want is for it to eat through the paintwork!
    Audi A4 S Line Special Edition 170bhp
  2. Re: Autosmart Tardis or Autoglym Tar remover?
    Dec 2007
    Belfast
    Hi.
    I would use the Autoglym tar remover.
    Put it into a spray bottle and apply to the area and let it work for a minute or two.
    The apply a small amount to a microfibre and rub it off.
    For heavily tarred areas spray a bit more onto the area and let it sit for a bit longer.
    Hope this helps
    1 1 0
  3. Re: Autosmart Tardis or Autoglym Tar remover?
    Feb 2009
    Glasgow UK
    Quote Originally Posted by belfastmark View Post
    Hi.
    Hope this helps
    +1 on the above.................the tar will just fall away.
    A good wash with warm soapy water, claybar then polish / protection etc as your choice
    1 1 0
  4. #4
    Nov 2011
    Essex
    Does the AG Tar remover also remove polish etc, would a polish be a mandatory step?
    At the moment i have a couple spots on the alloys, bodywork is ok but i was just thinking in the event of use on bodywork a few hours of wash and polish probably ahead
    sent from my Samsung Galaxy Tab using Tapatalk Android
    Furion
    Gone: Audi A6 Avant Le Mans 3.0 TDI 6 Speed Tiptronic
    Gone: VW Touareg Se Sport 3.2 V6
    Gone: BMW 325i M Sport
    Gone: Merc E240
  5. Re: Autosmart Tardis or Autoglym Tar remover?
    Feb 2009
    Glasgow UK
    Tbh, I'm not 100% sure.
    I guess to a degree it all depends on how serious you are about your car and its finish?
    What I mean by that, is I'm all up for keeping my car in great shape, personally, I wouldn't necessirily polish after and haven't in the past, but some would.
    I'd put my car up there with most cars for cleanliness and the paint in good shape for age / mileage.
    Before polishing you really need to take paint depth readings. You're cutting clear coat and that's not something you want to do to excess.
    1 1 0
  7. Re: Autosmart Tardis or Autoglym Tar remover?
    Feb 2009
    Glasgow UK
    You're right Esh, good call.
    I get the feeling that the OP isn't that far advanced as far as detailing goes ( no offence Furion ) so paint depth gauges
    for readings may be a little too far.
  8. Re: Autosmart Tardis or Autoglym Tar remover?
    Whenever I see polish mentioned, I feel the need to warn regards paint (or more accurately clearcoat) depth and taking accurate readings before cutting into it.
    Bit like timing belts & water pumps - forewarned is forearmed and all that.
    The quickest (and cheapest) method to an ok finish is to degrease (foam/degreaser/clay etc), wash (good quality shampoo and a mitt), seal (my current fave is carlack longlife) and wax (mine's currently wearing CG's XXX - a wax I've found difficult to better)
    If you find the finish isn't up to the standard you want, that's when you look at more aggressive treatment of your paint.
    1 3 0
  9. Re: Autosmart Tardis or Autoglym Tar remover?
    Dec 2007
    Belfast
    Eshrules, I understand your concern about polishing possibly doing some damage, though I personally wouldn't be worried about the odd coat of polish to correct any possible hologramming that would be left after the use of tar remover. I would definatly be a fan of a paint gauge being used before paint correction or buffing as there is more of a likelyhood of possible damage. Spot cleaning with tar remover doesn't normally cause any problems though on the other hand spot cleaning with polish can damage the paint.
    I would use a polish with minimum cut and do below the coachline, though I would only use this if after a good wash and dry doesn't do the job.
    Hope this helps.
    I can't understand people who use polish evertime they clean the car, if the paint doesn't look like it needs polished, don't polish it !!!
  10. Re: Autosmart Tardis or Autoglym Tar remover?
    May 2010
    Glasgow
    I decided to go for the Tardis and to be honest it's worked a treat. The tar literally just starts dissolving after a few seconds and with a light wipe of a microfiber cloth it's gone. Finish the job with some water from an open ended hose
    Sent from my GT-I9300 using Tapatalk 2
    1 1 0
  1. Instruments scratch remover
    By stuart in forum General Detailing/Cleaning Questions
    Last Post: 12-06-2012, 08:18 PM
  2. Autosmart
    By Yowfailed in forum General Detailing/Cleaning Questions
    Last Post: 14-03-2012, 01:05 PM
  3. Tar on Alloys - How to Remove?
    By Guest 2 in forum General Detailing/Cleaning Questions
    Last Post: 16-01-2012, 09:41 AM
  4. Tar on paintwork
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-02-2010, 12:39 AM
  5. Tar spots on paintwork!!
    By sherlockuk in forum General Detailing/Cleaning Questions
    Last Post: 21-09-2008, 08:40 PM
