Thread: A8 D3 Parking brake
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: A8 D3 Parking brake
    #11
    Nov 2012
    A, A
    Thanks Snap, will try it and feedback.
  2. Re: A8 D3 Parking brake
    #12
    Dec 2015
    England nelson
    Hi o want to ask did you finde what problem was with the brakes for your audi a8 thanks
  3. Re: A8 D3 Parking brake
    #13
    Mar 2010
    Bicester uk
    Tom, as far as I can remember the pb motor was replaced. You don't say what your problem is but I have had issues with the epb since when I get a fault light come on. It usually resets itself when I next use the car. But experience has shown me that if you are getting the mil coming on frequently then park the car without engaging the epb and you will then hear the motors recalibrating themselves like snapdragon says earlier in this thread. Since doing this I haven't had a problem.
  4. Re: A8 D3 Parking brake
    #14
    Dec 2015
    England nelson
  5. Re: A8 D3 Parking brake
    #15
    Dec 2015
    England nelson
    Thanks for info
  6. Re: A8 D3 Parking brake
    #16
    Jun 2016
    Warwick
    Going to have to give this a try myself as have had the same issue, will report back tomorrow.
    I did read somewhere about trying 30amp fuses in the boot too?
  7. Re: A8 D3 Parking brake
    #17
    Jun 2016
    Warwick
    Alas, turns out mine needs calipers
  8. Re: A8 D3 Parking brake
    #18
    Jun 2006
    UK, Mids
    It gets us all in the end.
    Eurocarparts is pretty much cheapest at ~£180 with core refund on old part and they are brand new (not reconditioned).
    Audi A8 - 2015 - 3.0TDI
  9. Re: A8 D3 Parking brake
    #19
    Jun 2016
    Warwick
    Calipers replaced over the weekend but warning light back on this morning Off for another diagnostics read to see what's going on.
  10. Re: A8 D3 Parking brake
    #20
    Jun 2013
    Ely, UK
    I have had a similar issue and fixed it. Turns out the motor was fine but the shaft encoder (the drum that turns that has the 6 pointed spline that goes into the back of the caliper) was dirty.
    I fixed this by running the motor off the car (apply 12v, either polarity to the outer two big pins - the 1st and 4th pins - in the connector). Naturally you'll have already taken the motor off the caliper first. Fortunately that doesn't require removing the caliper.
    With the motor turning, use the end of a contact cleaning strip or similarly rough rag between the now rotating drum and the casing. Let the motor turn for about 10 revolutions to make sure the drum is now clean.
    Stick it back on the car and do the procedure as if you'd replaced the pads (open, close, set pad thickness etc.) and test.
    For me, this fixed the fault and the error codes would then clear.
    Andy
    Sent from my EVA-L09 using Tapatalk
  1. ABS, Parking Brake, Squeeking brakes and brake lights!
    By medvwb6 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-10-2011, 05:35 PM
  2. Parking Brake
    By DouglasB6 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-10-2009, 05:05 PM
  3. Please Help Parking Brake
    By ncsuresh in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-04-2009, 08:51 AM
  4. Question Parking brake
    By ionic in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-06-2008, 08:29 AM
  5. B6 Parking Brake ?
    By Roy in forum Passat - Archive Topics
    Last Post: 21-08-2006, 07:26 AM
