Thread: Electric. Problems
  1. Electric. Problems
    Sep 2007
    Hello, can anyone help or advise what the solution to my problems with my rear bumper sensors not operating,all four electic windows recline on there own accord,drivers door not locking with central locking button .
    Nov 2009
    46 Post(s)
    Fault code scan is a must.
    Does your rear wash wipe still work?
  3. Re: Electric. Problems
    Sep 2007
    Thanks for reply,my rear screen wash still working,but drivers electric mirror also not operating.
    Nov 2009
    46 Post(s)
    Ok scan is a must to see what the problem is.
    Where abouts are you?
  5. Re: Electric. Problems
    Sep 2007
    Away up in highlands,small town called WIck near John o groats and nearest Audi garage is 110miles away unfortunately.thanks again.
  6. Re: Electric. Problems
    Jan 2012
    Coding Something
    Have you just bought the car?
  7. Re: Electric. Problems
    Sep 2007
    No I have had car for two years,just over last two months developed this problem.If I disconnect battery will it clear codes ?
  8. Re: Electric. Problems
    Jan 2012
    Coding Something
    Well the mirror could be a door module issue, switch or wiring, so yes need to get vcds on this to test with the measuring blocks to see what its showing from the switch, the locks could be related to a conv module fault or water has leaked onto the module, overall as per Chris, need vcds on to test systems & log to ascertain issues.
  1. Question electric problems
    By osbornes2627 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2009, 10:22 PM
  2. Electric problems
    By gduff1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-03-2008, 07:21 PM
  3. electric window problems?
    By minty0_10 in forum Passat - Archive Topics
    Last Post: 11-01-2008, 11:58 PM
  4. problems with electric windows help
    By thrastra in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 30-10-2007, 01:25 PM
  5. electric window problems
    By nobby.arny in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-01-2007, 08:12 AM
