Thread: How to fix vibrating/loose engine covers - any ideas???
  1. How to fix vibrating/loose engine covers - any ideas???
    Sep 2011
    Melksham, Wiltshire, UK
    Just noticed a new vibration heard from inside the car....its been drivin' me mad! Seems to get worse at certain points in the rev range....presumably the resonant point of the vibration.
    Had the wife sat in the passenger seat today checking for vibrating or loose panels on a test drive....then she drove and I tried to find but alas, no joy in trascing the flipping vibration.
    In desparation, checked under the bonnet and found that both main plastic engine covers were loose....both ineer and outer ones sat on top of the engine. Took em' both off, had a drive and vibration gone!
    I then discover on further inspection bits of plastc sealing tape marks at random points on the cover! It look s like the previous owner or the ir garage had 'TAPED' the coers down!
    It looks like a couple of the fixings are broken -
    1) Can these cover fixings screws/clips be replaced?
    2) Can you buy both inner and outer covers?
    Thanks all....
    1999 GTi Turbo - Turbo Technics uprated turbo, Forge charge cooler, Jabba remap, Milltek SS system, Brembo GT brakes, Koni Sportlines, Neuspeed ARBs
  2. Re: How to fix vibrating/loose engine covers - any ideas???
    Jan 2012
    Coding Something
    They use the rubber bits to hold on to the engine brackets, so if the holders for these are broken, then its a new cover or you could bond the rubber bits in place with sikaflex.
  1. A6 2l TDI engine vibrating
    By aril in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-10-2011, 09:34 PM
  2. Vibrating engine
    By jnunn in forum Bora - 1998 - 2005
    Last Post: 09-04-2009, 12:40 PM
  3. Any ideas how to check/fix this fault?
    By benjie in forum VCDS - General Questions
    Last Post: 27-01-2009, 02:00 PM
  4. Vag-Com error codes, any ideas for fix?
    By abbeyhouse in forum Archive posts
    Last Post: 05-06-2007, 11:30 PM
