Thread: VCDS User Location Map
Page 30 of 31 FirstFirst ... 2028293031 LastLast
Results 291 to 300 of 301
  1. Re: VCDS User Location Map
    Jan 2020
    Surrey
    Anyone in Surrey I'm in need of help please
  2. Re: VCDS User Location Map
    Oct 2011
    Surrey, Farnham
    8 Post(s)
    Hiya, I'm in Farnham (GU9) and have the latest version of VCDS if thats of any help?
  3. Re: VCDS User Location Map
    Jan 2020
    Surrey
    any chance you can get them to guildford as car wont even run anymore happy to pay if you can get her running again i have the laptop that was used so hopefully everything has been saved on it.
    thank you
  4. Re: VCDS User Location Map
    Jan 2020
    Surrey
    Nowa have sent you a message as would really apprecaite your help and happy to pay for your time
  5. Re: VCDS User Location Map
    Oct 2011
    Surrey, Farnham
    8 Post(s)
    Hi Emma,
    Well, I'm not a mechanic... just a happy enthustiast of VCDS... I've done some VCDS coding on my 2 Audis and on a couple of friends VW. The most complex work I've done with VCDS is to diagnose a fault with a DPF pressure sensor, replaced the sensor and calibrated it... Your issue sounds quite complex as you are saying the car wont even start?
    But as it so happens, I will be in Guildford tomorrow (ice skating at Spectrum stadium). I dont mind passing by and doing a autoscan on your car (no charge) and then you can post the log file and see if you can get some answers to what needs doing on your car...
    PM me your address/phone#
    /Pete
  6. Re: VCDS User Location Map
    Jan 2020
    Surrey
    perfect i will do i have another thread open vcds help if you can pop a message on there as someone is alraedy surggesting what i can do and also have put the log scans on there maybe you may understand it better than i can.
    will pop you a messgae
    Thank you so much
  7. Re: VCDS User Location Map
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Read up here: https://www.vwaudiforum.co.uk/forum/s...hp/193443-Vcds. You'll probably need jump leads or new / borrowed battery as well.
  8. Re: VCDS User Location Map
    Apr 2020
    Lancashire
    Hi All, is there anyone with VCDS in the Lancashire area that can calibrate a new Steering Slip ring on my B8 8k5 when it arrives?
    Regards
    Sam
  9. Re: VCDS User Location Map
    Apr 2020
    North West
    Anyone with VCDS in Chester? My radiator fans won’t turn off when the cars off (after a recent radiator change)
    Thanks!
  10. Re: VCDS User Location Map
    Aug 2015
    Cambridgeshire
    Quote Originally Posted by Guest 2 View Post
    Notice - As of 29/04/2014, anyone who wishes to be placed onto the Map must have at least 10 useful posts on the forum to allow for communication between users.
    A user will be removed from the map after 6 months of inactivity on the forum however this can be reinstated if needed
    This map is to help VWAF users with diagnostic issues find another user who has the tools to read the faults using VCDS.
    Current Forum Sponsors who have VCDS have now been added to the Map, these can be found by a purple icon and normal forum users are shown as a blue icon.
    Map Link - VWAF User Location Map - VCDS - Google Maps
    Could I please be added at Peterborough (PE6)
    I have the latest HEX-V2 but I am limited to 8 licences left, currently.
  1. Vagcom/VCDS User Locations
    By Col in forum VCDS - Users Locations
    Last Post: 20-02-2024, 01:20 PM
  2. VCDS User help required in Rochdale North West Area Please
    By f2raf in forum VCDS - Help Requests
    Last Post: 17-09-2011, 05:05 PM
  3. New VCDS ODB2 user- Lancashire
    Last Post: 08-09-2011, 10:47 AM
  4. vag-com/vcds user needed south manchester .2005 golf 2.0 tdi mkv..
    By joseph76 in forum VCDS - Help Requests
    Last Post: 25-04-2010, 05:25 PM
  5. MAP Sensor location?
    By MikiebV6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-12-2009, 05:41 PM
