Thread: High Pressure in Coolant Tank
Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. Re: High Pressure in Coolant Tank
    #21
    Pembrokeshire
    22 Post(s)
    i have tested many diesels with this kit, and only once had it change colour a tiny bit. mind you, i am not convinced it changed colour because of gas in the cooling system or a contaminated filter on the tester.
  2. Re: High Pressure in Coolant Tank
    #22
    london/ UK
    The sniffer tests only work on petrol engines and even then you need to take them with a pinch of salt ! I had a 2.0 petrol passat with a cracked head a few weeks ago, owner had a backstreet garage do a timing belt job + water pump and did not bleed the system. Subsequently the owner put cold water in the hot engine as it was pressurizing the coolant tank and water went trough the relief valve. It never overheated and temp. stood bang on 90 C on the gauge. Took the head off, sent it for skimming and pressure test and then refitted with a new head gasket and head bolts. It did the same after 3-4 days, water dropping from the header tank, told the chap his block is cracked so he needs a 2nd hand engine, he did not take it nicely !
  3. Re: High Pressure in Coolant Tank
    #23
    May 2018
    Northern Ireland
    Quote Originally Posted by hibbsy21 View Post
    As most of you will know I have just upgraded the turbo on my 1.9tdi. All is well and just doing a few MOT repairs. But I am not happy about the coolant. The main pipe that goes from the head to the radiator is really hot and hard after a run. And when I undo the tank cap it releases a hiss of pressure and the little pipe that goes into the tank shoots water through it into the tank. Just a bit confused as to why and i am not happy with it.
    The only things i can think of are; the tank cap is blocked (already cleaned and blasted with an air gun), a blockage elsewhere in the system (going to drain and flush out thoroughly), the turbo is creating a high pressure inside the head....? (actuator not set up properly yet and running a massive boost!)
    Any other thoughts?
    Rich
    Did you ever get this sorted having the same problem cheers
  4. Re: High Pressure in Coolant Tank
    #24
    Oct 2018
    Birmingham
    Quote Originally Posted by ShaneA4 View Post
    I also have the same problem has anyone resolved the issue?
  5. Re: High Pressure in Coolant Tank
    #25
    Mar 2016
    Minervois, France
    32 Post(s)
    Quote Originally Posted by Victordugg View Post
    It is normal for the pipe to get quite hot and for the tank to be under pressure once the engine is at working temperature. The cap should not be removed when it is hot.
    Is your temperature gauge reading higher than normal, i.e. more than 90?
    Are you removing the cap before the engine has cooled down?
    1996 A4 Avant 1.8T engine code AEB automatic with 62,000 kms - 39,000 miles on 21/04/19.
    VW T25 Camper, Alfa 33 1.4 ie, Alfa Sprint 1.5 QV, 2 Alfa 33's for parts.
  6. Re: High Pressure in Coolant Tank
    #26
    Oct 2018
    Birmingham
    My question was with regards to the original post 'high pressure in coolant tank' i'm having the same problems, pressure got so high it popped the radiator (which was the first thing the mechanic changed about a year ago). Ive also changed the water pump and thermostat still no joy. Thinking of buying a second hand engine but i think i'm going to have one last go with changing the oil cooler. But I the oil isn't mixing with the coolant, can it still be the oil cooler? Also does anyone know how I can tell if it's got an egr cooler, where would it be located? I've read in another thread, someone with similar problems changed this and problem as fixed.
  7. Re: High Pressure in Coolant Tank
    #27
    Dec 2009
    Belfast
    Hi guys, after chasing a similar problem on my b5 with a 115bhp ajm engine code it turned out to be the headgasket. I was having similar issue; rock hard top hose, pressurised bottle etc. I sniff tested it and it passed sniff test, changed expansion bottle and cap with genuine parts and a genuine stat. Nothing resolved it till I pulled the head. Hope this helps.
  1. High Pressure in Fuel Tank
    By I.T. in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-04-2011, 11:32 AM
  2. Please Help Bora 2.0 petrol tank back pressure
    By vw4sii in forum Bora - 1998 - 2005
    Last Post: 18-12-2008, 11:14 AM
  3. Constant Pressure in Expansion Tank
    By copthis1 in forum Golf MK3 - 1993 - 1999
    Last Post: 30-03-2008, 03:54 PM
  4. Engine Cutting Out, Tank Pressure Valve N80
    By Raitis in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-03-2008, 09:13 PM
  5. coolant expansion tank
    By remember1t in forum Golf MK2 - 1984 - 1992
    Last Post: 09-10-2007, 09:30 PM
