Thread: The usual Hard brake pedal, seized binding NSF brake - Culprits please?
Results 1 to 10 of 14
  1. The usual Hard brake pedal, seized binding NSF brake - Culprits please?
    Morning all
    The Mrs's A6 1.9TDI 99vintage 150K
    We have the hard pedal, seized and smoking hot NSF
    Plenum is dry as I removed the bung two yeras ago after it buggered the indicators and soaked the carpets
    In the last three weeks
    Brake booster - replaced ( no rust on show)
    Blake lines - replaced
    NSF calliper - stripped and cleaned
    What do I spend my £££ on next?
    All the hoses from the brake boost including the small vacuum hoses?
    Or Master cylinder?
    Or calliper
    Im just wondering if anyone has ever got to the bottom of this problem and there is a one fix cures all
    Its my fault as I was complimenting her car on being so reliable. Unlike my 245K A62.5tdi
    Ta in advance
    Mark
  2. Re: The usual Hard brake pedal, seized binding NSF brake - Culprits please?
    1841 Post(s)
    When I have had this it has only been the servo full of rust when we replace the M/C anyway so that would seem a good place to start.
  3. Re: The usual Hard brake pedal, seized binding NSF brake - Culprits please?
    Thanks Crasher
    I will get the moths out of the wallet
    Mark
  4. Re: The usual Hard brake pedal, seized binding NSF brake - Culprits please?
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi is it just the NSF sticking on?
    Undo the join between metal brake pipe and flexi brake pipe a few turns get some one to press the brake pedal, you should get a reasonable gush of brake fluid, tighten this back up. undo flexi brake pipe to brake caliper (does the wheel turn free?) if so get some one to press the brake pedal, does brake fluid gush out? If yes tighten back up, press brake pedal a few times then try and turn wheel, does it turn if the wheel does not turn, brake stuck on change flexi brake pipe
  5. Re: The usual Hard brake pedal, seized binding NSF brake - Culprits please?
    1841 Post(s)
    Quote Originally Posted by mebedforduk View Post
    We are assuming he has already replaced the hose by his first post.
  6. Re: The usual Hard brake pedal, seized binding NSF brake - Culprits please?
    Pembrokeshire
    22 Post(s)
    presumption is the mother of all .......................
  7. Re: The usual Hard brake pedal, seized binding NSF brake - Culprits please?
    1841 Post(s)
    **** up's...
  8. Re: The usual Hard brake pedal, seized binding NSF brake - Culprits please?
    In this instance, presume would be correct
    As Im up to my armpits with work at the moment I committed the godly sin of paying someone to work on one of our cars
    Hes a VW main dealer mechanic who erm, fettles cars outside of work to gain erm experiance and as a hobby to keep him away from the wife.
    Flexi replaced plus steel pipe full length as it was rusted into the flexi connector
    Ive been looking at the tangle of vacuum hoses tonight but athough they look a bit frayed there is no hissing when the brakes are being pumped even if I tug them about
    Mechanic Matt is going to ask in the workshop in the morning but his first diagnosis was sticky calliper or servo, but of which are now ruled out. He did suggest petrol and a match though....................
    Now the beemer bike has sprung an oil leak
    Ta all for the replies
  9. Re: The usual Hard brake pedal, seized binding NSF brake - Culprits please?
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi all OK I will try not to Presume!!
    The N/S/F is the only caliper sticking on? After all above work carried out.
    Jack car up all four wheels off the ground.
    Go back to basics (I know you say certain items have been done but do they work correctly?)
    Remove N/S/F wheel, ensure wheel turns free, push pads back in caliper Does the piston move freely?
    Move caliper on slides does caliper move free on slides?
    N/S/F wheel spins OK?
    Clamp flexi brake hose (for N/S/F) apply brake on off several times; check all other wheels spin free OK?
    Remove clamp from flexi pipe, apply brake on off several times N/S/F wheel stuck? Or OK.
    If sticking I would then go with crasher change master cylinder. Is there a brake balance valve for the N/SF? Only other item is ABS pump.
  10. Re: The usual Hard brake pedal, seized binding NSF brake - Culprits please?
    [QUOTE=mumutley;732894]Hi all OK I will try not to Presume!!
    Fantastic and simple idea
    I will try it at the weekend, or if it ever stops raining
    The Missis gingerly took it out today and it didnt start playing up until she got to her 3 mile away destination.
    We live in the sticks are seeing two cars at the same time is considered rush hour so she was steady with the handbrake at the ready
    Did you know that unmade roads and Audi suspenion legs dont go well together?
    And to think she convinced me away from Citroen XMs to get away from having to fix em all the time.
    I prefer problems where they either work or dont work
    Thank you again
  1. Brake pedal going hard
    By man_utd_99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-10-2014, 06:35 PM
  2. Question Hard brake pedal
    By JON35Y in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-04-2012, 10:54 PM
  3. Hard brake pedal
    By riels in forum Ireland
    Last Post: 26-02-2010, 03:44 PM
  4. Question Hard brake pedal
    By mykmob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-12-2009, 08:54 PM
  5. Brake pedal going hard (Please help)
    By dubstar81 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2009, 08:41 PM
