hi guys, i recently did my rear pads and discs on my B5 Passat and it was pretty easy. My mate owns an A4 B7 2.0tdi 57 plate Avant and the rear brakes need renewing. i said i could probably do them for him as i thought the setup was pretty much the same as my B5. So was wondering if there was anything different from mine to his?
Is there a securing screw (T27) on the disc??
Do I need to remove the caliper carrier to remove the disc or can I, like my passat, remove the disc without removing the carrier?? If i do need to remove the carrier what nut/bolt is it? 8mm allen key/15mm bolt??
Ive got a rewind tool for the piston and other tools to do the job. just didnt want to take the wheel off and find a special nut/bolt like the T27 there waiting to be undone
cheers
Paul
