I am planning on changing the discs/pads on my 1.4 Lupo(Y).
A couple of questions
What size are the bolts that hold the caliper on and are they normal nuts or hex nuts. I heared they were 10mm?
Would you normally loosen the cap on the brake fluid reservoir before resetting pistons?
Where is the copper grease meant to be applied?
Anything else I should know before starting?
