Thread: Brake fluid reservoir top come off!
  1. Brake fluid reservoir top come off!
    Jun 2012
    Blackburn
    Hi, just got my 2004 A3 this week and whilst cleaning engine bay I whiped top of brake reservoir and the top part with the yellow icon on came apart from the screw top cap. On closer inspection it had been glued on before. I' ve glued it back on but I'm still getting the red warning light coming on dash.
    Does the sensor have to go back in a certain way?
  2. Re: Brake fluid reservoir top come off!
    Jun 2012
    Blackburn
    Sorted, put a little brake fluid into the body of the sensor holder and light gone out. Will sort a replacement cap out for permanent fix.
  3. Re: Brake fluid reservoir top come off!
    Jan 2011
    East Kent
    Glad that you got it back on. You should look at when the brake fluid was last changed - under normal conditions it should be changed every 2 years, because it degrades over time, as it absorbs moisture. This isn't going to be helped by your cap not fitting properly, and you don't know how long it has been like that.
  4. Re: Brake fluid reservoir top come off!
    Jun 2012
    Blackburn
    Yes good call, I found a receipt for some brake work done in Feb but does not mention a full change. Slowly starting to build up a list of jobs.
  5. Re: Brake fluid reservoir top come off!
    Jan 2011
    East Kent
    For your info, I have written up the service schedule here:
    Question Cambelt change interval - Page 2
  1. brake fluid reservoir is split
    By carlover in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-05-2012, 10:43 PM
  2. Brake fluid reservoir
    By cheekyelf in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-05-2012, 10:50 PM
  3. Overfilled brake/clutch fluid reservoir
    By Passatman10 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-07-2011, 04:13 PM
  4. Question Brake fluid top up - im confused
    By bambamjj in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-01-2011, 10:35 PM
  5. Clutch / brake fluid reservoir?
    By 3narf in forum Touran - Sharan - Caravelle
    Last Post: 17-08-2009, 03:49 PM
