Thread: Slamming mk2 Scirocco and going wide... wheel size question
  1. Slamming mk2 Scirocco and going wide... wheel size question
    Jul 2008
    Tyne and Wear
    Hi (first post since 2008) I'm planning on slamming my Scirocco with coilovers, now my question relates to wheel size and will they rub or catch and will I be able to fully drop it down?
    I'm planning on fitting a set of deep dish 15x8J ET25 with stretch rubber and quite possibly 25mm hubcentric spacers all round, either that or a set of 16x8J ET25 fronts and 16x9J ET35 rears. I reckon in both cases I might need to roll the rear arch but my concern is the front catching on lock etc.
    Any helpful advice appreciated!
  2. Re: Slamming mk2 Scirocco and going wide... wheel size question
    1834 Post(s)
    Using a 7x15 ET 35 with 195/50 15 tyres you can just about get away with no rubbing and a lowering of 40-mm. If you go ET25 and 8 inch with 195 rubber (pushing it a bit) you may get some outer arch rubbing but less at the front inner on full lock than with an ET35. If you fit Et25's with 25-mm spacer you will have ET0 and that will cause you as much trouble as fitting 225/15's on Et35's.
  1. Steel wheel size question for 2.0TFSI with cross drilled discs
    By warp_speed in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-12-2011, 12:58 PM
  2. New Scirocco question for owners
    By maisbitt in forum Scirocco - 2008-
    Last Post: 09-04-2010, 05:04 PM
  3. Scirocco Storm MK2
    By gervulstrammer in forum Scirocco - Corrado
    Last Post: 08-01-2010, 05:36 PM
  4. Can't open bonnet on MK2 scirocco
    By Captain Answer in forum Scirocco - Corrado
    Last Post: 26-10-2009, 10:53 PM
  5. Question what size spline tool for MK2 cylinder head bolts
    By Halo Le Fish in forum Golf MK2 - 1984 - 1992
    Last Post: 15-12-2008, 02:56 PM
