Thread: Cam shaft position -timing over-advanced or system performance (bank 1)
  1. Cam shaft position -timing over-advanced or system performance (bank 1)
    Mar 2010
    bolton
    WHAT SHOULD I DO?
    I have an A3 1.8T 2009. 19K miles. This morning it failed to start. I had an interim service done 2 weeks ago at the local Audi dealer and driven it locally since then.
    This morning the car failed to start and after speaking wwith Audi they advised that since the car is 3 weeks out of warranty (ie just over 3 years old) they don't want to know.
    I called out Greenflag who diagnosed the fault as CAM SHAFT POSITION -TIMING OVER-ADVANCED OR SYSTEM PERFORMANCE (BANK 1)
    I went back to Audi who advised that they will look at it for a diagnostic fee of £126.
    What should i do? Should i insist the Audi look at it for free as it is just out of warranty or do i pay them the diagnostic fee. On the other hand should i go to an indi?
    I had a look on google to see what CAM SHAFT POSITION -TIMING OVER-ADVANCED OR SYSTEM PERFORMANCE (BANK 1) means and it advises that the problem maybe
    1. incorrect camshaft timing
    2. wiring problem in intake timing control valve control solenoid system
    3. continuous oil flow to vct piston chamber
    4. failed timing valve control solenoid (stuck open)
    I know that without someone looking at the car it can't be diagnosed but can anyone advise if it is a common problem and what are the chances it could be one of the 4 things listed above (typical costs to fix??)
  2. Re: Cam shaft position -timing over-advanced or system performance (bank 1)
    1840 Post(s)
    Firstly you need a proper code read that gives a VAG or P code fault code number. What is your engine type code, CDAA
  1. Oh pants cam shaft timing boob!!
    By fieldy1978 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 25-02-2011, 11:29 PM
  2. Question VW Golf position of bank 1 o2 sensor
    By pjsouthernwood in forum Golf MK4 - 1999 - 2004
    Last Post: 28-06-2010, 04:51 PM
  3. Attention Shark Performance Bank Holiday BBQ!
    By shark_90 in forum Shows & Events
    Last Post: 28-04-2010, 07:38 PM
  4. Cam shaft position sensor 1.8 GTI
    By Jayc530 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-03-2008, 09:45 PM
