Thread: OEM LED number plate light fitted to A6 .. Success!
Page 2 of 22 FirstFirst 123412 ... LastLast
Results 11 to 20 of 214
  1. Re: OEM LED number plate light fitted to A6 .. Success!
    Feb 2009
    Glasgow UK
    Hey Chris, nice mod mate.
    I did this myself some time ago with Leds with a built in resistor for not a lot of money and also with no errors. They make a big difference.
    Thanks for sharing Chris
  2. Re: OEM LED number plate light fitted to A6 .. Success!
    Mar 2011
    Clitheroe, England
    11 Post(s)
    Will give those suggestions a go, cheers guys. That must've been frustrating Chris, you thought you were just going out to get a couple of snaps & realise theyr'e not aligned correctly, I bet a few choice words were uttered . One of them trial & error jobs I guess, you won't know if it's right til you can see the direction of the lightbeam.
    The Only Way Is A6!
    46 Post(s)
    Just one of those things really!
    I noticed that the a3's plate is mounted closer to the light so it's definitely the positioning of the plate itself which is crucial to get a good result.
    I might just remove the holder altogether and just stick the plate on but luckily number plate stickers are only £1 for 10 so not bad.
  4. Re: OEM LED number plate light fitted to A6 .. Success!
    Aug 2007
    New Romney Kent
    Not sure if you know this or not, but you can turn the cold diagnosis off for the number plate lights in VCDS
    I tried that before the mod, despite the option being in VCDS it does nothing on MY09 cars onwards (certainly not on our MY11's) and you still get the bulb out warnings on the DIS / maxidot.
    VCDS HEX-NET registered owner (Covers all VAG cars)
    PM me if you require scans or adaptations doing in S.E. Kent, can unlock SFD.
    Audi TTS 8S
    VW ID.3 Tour
    46 Post(s)
    Progress pics - gonna keep the holder off and see if that makes a difference
    46 Post(s)
    Got some night pics taken
    Look really good and the pictures don't do them justice
    If I blank out my plate it will take the glow away so 'like' this post and I will send direct to pm inbox
    0 5 0
  7. Re: OEM LED number plate light fitted to A6 .. Success!
    #17
    Mar 2011
    Clitheroe, England
    11 Post(s)
    You still got mine Chris? I'd like to see the results in the darker shots, plan my next mod. Plus if there's no error code it's a bonus, there are some benefits to me having an older car after all.
    The Only Way Is A6!
    46 Post(s)
    Im on my phone do I'll just pm you the image link
    They look really good, recommend them highly!
    Pm incoming
  9. Re: OEM LED number plate light fitted to A6 .. Success!
    #19
    Sep 2011
    Lurking over a keyboard ...
    Thanks for photos, great thread , makes it so much easier for people to do and see potential pitfalls and the workrounds
    Great tips from Gizmo68 for later model owners as well
  10. Re: OEM LED number plate light fitted to A6 .. Success!
    #20
    Jun 2006
    UK, Mids
    It takes very little OHMS to fool the bulb check on these lamps.
    150-160 OHM 2 WATT resistor piggybacked on each side was enough for me which is around a 1.2W load on each side.
    Audi A8 - 2015 - 3.0TDI
    2 1 0
  1. Audi OEM Led Number Plate Light fitted .. Success!
    By Guest 2 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-08-2017, 04:08 AM
  2. Led number plate lights
    By Y90USF in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-02-2011, 10:20 PM
  3. Rear LED number plate
    By tlionhart in forum Chat - Anything with wheels
    Last Post: 25-10-2010, 07:10 PM
  4. LED Side lights & number plate light
    By Adam Moran in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-02-2010, 10:04 PM
  5. LED number plate bulbs finally fitted with pics! NO ERRORs also got my side lights!
    By Killer passat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-12-2009, 10:47 AM
