Thread: thinking of changing my standard seats for half leather/leather.
  1. thinking of changing my standard seats for half leather/leather.
    Apr 2012
    Ireland
    Hi All
    I am thinking of changing my standard seats in a 1.9 tdi avant a4 for a half leather or even full leather they dont have to be heated or anything but am wondering what are my options and will I run into any problems namely with the air bags in the seats or is it just a matter of exchanging them or will have to go into the ecu and change parameters just wondering has anyone carried this out or am I getting into something I may regret later
    Thanks all
  2. Re: thinking of changing my standard seats for half leather/leather.
    Aug 2007
    New Romney Kent
    I have not done this on an A4 but have done it on several other VAG models.
    1/ Disconnect the battery
    2/ Remove seats - make sure you unplug the wires!
    3/ Check the airbag plugs (yellow ones) are the same as on the seats you are going to fit - if not then these need changing over
    4/ Fit new seats and reconnect the wires
    5/ Reconnect the battery
    If you connect the battery and turn the ignition on with an airbag unplugged then you will need someone with VCDS to turn off the airbag light!
    VCDS HEX-NET registered owner (Covers all VAG cars)
    PM me if you require scans or adaptations doing in S.E. Kent, can unlock SFD.
    Audi TTS 8S
    VW ID.3 Tour
  3. Re: thinking of changing my standard seats for half leather/leather.
    Apr 2012
    Ireland
    Gizmo68
    thanks for the reply,so the only thing I have to really worry about is the plugs for the airbags if they are not the same does that mean they are not compatible with my own (if they are different, when you change the plugs will the ecu recognise them) can they be made to fit and if so do you know how.
    cheers.
  4. Re: thinking of changing my standard seats for half leather/leather.
    Aug 2007
    New Romney Kent
    Yes 'simply' swap the plugs over, I even changed 2 wire airbags (seat side) to 3 wire airbag plugs (car side) and they were perfect, just make sure if the wires are different colours you connect them the correct way.
    On the Vehicle I had:
    Brown - Earth
    Green - Airbag Control Unit Plug T75a
    Yellow - Airbag Control Unit Plug T75a
    But the seats were:
    BLACK - Airbag Control Unit Plug T75a
    BLUE - Airbag Control Unit Plug T75a
    As they did not need an earth, if the seats come out of a similar model and age car then the plugs may well be the same anyway, there is no VCDS coding needed.
    Audi TTS 8S
    VW ID.3 Tour
  1. Replies: 0
    Last Post: 08-10-2011, 05:41 PM
  2. Golf models on a hiding for nothing... With leather now standard
  3. Installing standard s4 leather seats
    By hardenpeter in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-10-2011, 04:48 PM
  4. Alcantara/half leather - affect the desireability?
    By edmond in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-10-2009, 07:14 PM
  5. a3 2002 suede seats swapped for 1999 leather seats, airbag resistor mod?
    By tonto2k in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 24-07-2009, 01:00 AM
