Thread: corrado g60 1990 instrument cluster/clocks
  1. corrado g60 1990 instrument cluster/clocks
    Mar 2008
    hi,i have recently removed an old clifford immobilizer from my corrado so that i can fit my new cobra alarm.
    I wanted to get the wiring close to standard before fitting the cobra.When i turn the ignition on i dont get a battery check light or oil check light on the bottom of the cluster which i am certain was there before,i do get a coolant check light and also hand brake light and the rest of the cluster seems to work but i cant help thinking i have lost an earth or supply to the cluster by removing the immobilizer,the immobilizer wiring was a immobilizer cut to the crank/starter wire terminal 50 and an immobilizer cut to the ignition supply terminal 15,live and earth,has anybody got a wiring diagram for the instrument cluster/clocks? cheers
  2. Re: corrado g60 1990 instrument cluster/clocks
    Sep 2007
    Essex boy in Suffolk
    Bit of a late answer and you've probably sorted it now but for anyone else with Corrado cluster wiring questions heres a link to the everything you ever wanted to know about Corrado clusters
    VWVortex.com - The unofficial Cluster Swap thread
    Graham
    Still pretending to know stuff.
    Golf 6 .:R
    Corrado 20vT - BBS RCs, Leather, Bremo's, TFSI and DSG
  1. selling my Corrado G60
    By Dubite in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-08-2008, 01:30 PM
  2. A2 Instrument cluster (Clocks)
    By Sarge786 in forum A2
    Last Post: 21-04-2008, 07:32 PM
  3. corrado g60 cutting out
    By simon hs in forum Scirocco - Corrado
    Last Post: 25-01-2008, 02:05 PM
  4. corrado g60 running problem
    By simon hs in forum VCDS - General Questions
    Last Post: 25-01-2008, 12:23 PM
  5. corrado g60 hell
    By nadagila in forum Archive posts
    Last Post: 02-10-2007, 02:21 PM
