Thread: A6 1.9tdi sport 2002, various problems, please help !!!
  1. A6 1.9tdi sport 2002, various problems, please help !!!
    Sep 2008
    Aberdeen
    Hi guys, this is the only place i could see to post this thread, I just bought a 2002 A6 1.9tdi sport ( mrs wrote off my passat )
    Firstly i have changed my thermostat as coolant and oil temp was not reaching optimum temperature. that is now fine.
    My speedo is reading 15-20 mph more than what i am traveling at ( confirmed with sat nav ) where is the speed sensor on this model ?
    i susspect its driverside wheel arch but could be wrong !! could it be the gusge or the sensor ?
    Also my fuel gauge reached 1/2 and light came on so i topped it up ( £83 later ) realised i had a problem, the gauge now reads off the scale, I have found the sensor in the boot ( not under the back seat as other threads suggest ) i was just wondering if its just a case of changing the sensor or the whole unit ?
    Any help would be greatly appreciated
    Cheers Steve
  2. Re: A6 1.9tdi sport 2002, various problems, please help !!!
    Aug 2008
    Somerset
    Hi Steve
    The sensor could be located in 2 places as there were two versions around that time. Either G22 sensor in the left hand side close to the output shaft on the gearbox (you should be able to access it from the engine bay. It sits on top of the driveshaft collar) or no sensor and it used the front left abs sensor in the bearing hub.
    Hope that helps with the speedo
  3. Re: A6 1.9tdi sport 2002, various problems, please help !!!
    Sep 2008
    Aberdeen
    Quote Originally Posted by dulux72 View Post
    Hi Steve
    Thanks for this i will get a look at it in the morning and see how i get on I will let you know my findings !!
  1. Replies: 3
    Last Post: 12-11-2011, 07:13 PM
  2. Please Help Audi a4 b6 avant 1.9tdi sport 2002
    By geordieaudi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-08-2011, 09:03 PM
  3. Question Audi A4 Sport 2002 (automatic) - a few problems
    By dannyboy75 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-06-2011, 08:09 AM
  4. audi a6 1.9 tdi sport 2002 starting problems
    By gpin1 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-12-2010, 04:23 PM
  5. Gearbox Problems - A3 130 sport (2002)
    By gixer750 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 01-04-2009, 10:47 PM
