Thread: **UPDATED** Adding images to posts using "insert image" option
  1. **UPDATED** Adding images to posts using "insert image" option
    Feb 2004
    Yorkshire
    34 Post(s)
    For some reason vBulletin have changed the way images are attached, and sized when putting in posts...
    So, a quick guide....
    1. Start you post
    2. Click the "Insert Image" icon in the tool bar.
    3. Select "from computer" from the "insert image" pop up box:
    4. Select your image and upload it...
    This is pretty much the same as before, but this is were the changes are.
    5. Once your image appears in your post, but BEFORE you click "Submit New Thread", DOUBLE CLICK THE IMAGE!!!!
    You will be presented with the options to select the size location you want to appear
    Then click "Submit New Thread"
    I have no idea why they have made these changes, seems a backwards step to me, but I have no say in the matter ..
    Hope this helps.
    Stuart
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Member of the Institute Of Advanced Motorists
    Member of Skoda Owners Club GB
    Automotive Parts Specialist - VAG Group Automotive Parts Specialist
  2. Re: **UPDATED** Adding images to posts
    Nov 2009
    43 Post(s)
    I take it my old guide is now redundant because of the change, or does it only apply to the image upload?
  3. Re: **UPDATED** Adding images to posts
    Feb 2004
    Yorkshire
    34 Post(s)
    This applies if you want to put an image n a post using the "insert image" icon, I think your post applies to the "attachment" option
  4. Re: **UPDATED** Adding images to posts
    Nov 2009
    43 Post(s)
    Yes, I see. Yep mine is the attachment .. Doh!
  5. Re: **UPDATED** Adding images to posts
    Feb 2004
    Yorkshire
    34 Post(s)
    Just tried it, the image re-size option is the same... I will update your post
  1. worn alcantara insert - replacement option?
    By Tricky11 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-07-2009, 10:35 PM
  2. tv image will be displayed only in stationary
    By nica_tibi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-04-2008, 10:10 AM
  3. re size image? jpeg
    By hogiapesda in forum Chat - Completely Off Topic
    Last Post: 29-12-2007, 12:18 PM
