Thread: Rear washer hose leaking
  1. Rear washer hose leaking
    May 2012
    Basildonp
    Just discovered drivers footwell under water,used rear washer other day.stank of cats p!,,. So decided to flush it through only to discover it was filling the footwell.Turns out there's a bodged repair on the hose that's come apart.It was done by pushing the existing ends into a larger bit of rubber tubing.how or why it severed in the first place I've no idea.it runs in the wiring loom along doorside under plastic trim and carpet .worrying!.Any ideas for a good fix?
    Does anybody know how to remove the bonnet release catch,so I can lift the carpet try and dry it out
    thanks
    Regards Doug
  2. Re: Rear washer hose leaking
    Mar 2008
    High Wycombe
    If it's a 1971 Sunbeam Stiletto, then I seem to recall that there's 2 screws holding the release catch onto the wheel arch. But you should be able to remove the carpet without moving the catch if you're careful.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Rear washer hose leaking
    Oct 2005
    What Nick is saying is, without knowing what the car is, we can't help you at all.
    Welcome to VWAF
  1. Rear washer leaking - advice please?
    By wid77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-11-2011, 11:26 AM
  2. Avant Rear washer hose route?
    By stickleback in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2011, 07:55 PM
  3. A6 Avant rear washer hose
    By kerrywalpole in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-04-2011, 04:02 PM
  4. Rear Washer leaking in rear quarter
    By kateb in forum Golf MK4 - 1999 - 2004
    Last Post: 03-02-2011, 05:05 PM
  5. leaking rear washer pipe
    By thewall in forum Polo - Derby - Lupo - Fox
    Last Post: 22-12-2010, 04:48 PM
