Thread: camshaft change!
Results 1 to 10 of 10
  1. camshaft change!
    Apr 2012
    witham uk
    Just replaced my camshaft on my B6 1.9tdi pd (105hp) after fault developing 5 days ago, I decided to replace head gasket whilst I was at it as I have had a water leak ever since I have had it!
    Bolted it all back, with no issuse, fired it up, all good, felt a bit flat on the throttle, took it up the road, and it was very under powered almost like it had no turbo!
    Spent a day faffing around looking for air leaks on the vaccum side, checked the boost, seems all good, maf sensor etc un able to find anything at fault.It is drivable although alittle slow off the mark and the fuel ecconomy is low. (use to run at about 46mph its now 38mph)
    All I can think of is that it might need some sort of adjustment/set-up on the injectors.
    Does any one know?
    I didn't want to play with the adjusters on the top of the injectors. I'm not that technical!!
    Hope this all makes sense!
  2. Re: camshaft change!
    Apr 2007
    France
    12 Post(s)
    Any chance that you didn't get the timing right?
    2006 (Dec.) B6 2.0TDi 140 Confort | Moka anthracite nacré | CControl | Highline MFD | Chrome Grill | Meta Targa rear parking sensors | Debadged
    1996 Laguna 2.2D
    1977 MGB roadster
  3. Re: camshaft change!
    Jun 2007
    Up North
    Correct cam shaft?
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  4. Re: camshaft change!
    Apr 2012
    witham uk
    I did wonder about the timing, The right timming pins were used. It doesn't knock or anything, sounds nice infact, might be worth checking tho!
    I would hope it's the correct shaft, got it from euro parts, they took the reg number. It all looked good!
    Thanks for the replies!
  5. Re: camshaft change!
    1836 Post(s)
    Before you do anything else, get it read for fault codes.
  6. Re: camshaft change!
    Apr 2012
    witham uk
    Thanks Crasher, that was the first thing we did, came up with glow plugs, open circut on 3&4. Changed them!
    Didn't think it was that!
    I did change the maf censor, it did changed it slighly but not for long! boost was improved but fuel ecconomy was still pants!
    Going to take it to a diesel place near me! They can give it a look over!
    For sale passat 1.9tdi in black. One careful owner, and one not so careful!!!! Grrrr!
  7. Re: camshaft change!
    1836 Post(s)
    Was the AMM (MAF) you fitted genuine VW or "other"? Are there any fault codes now? If there are no codes, fit a genuine VW dealer supplied AMM and see what happens. If it cures the problem, take the spurious AMM back and ask for a refund plus you may have an issue if you have no exchange unit to hand back.
  8. Re: camshaft change!
    Norfolk
    I would get a complete engine measuring block read out using VCDS. That will give Crasher some straws to grasp.
  9. Re: camshaft change!
    Dec 2011
    London
    Did you manage to get to the root of the problem then?
    Nov 2006
    derbyshire
    What was your original fault before replacing the cam and what was wrong with the old cam??
  1. Question Camshaft seals - change them or leave them be?
    By davdi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-05-2009, 06:45 AM
  2. Camshaft
    By tick73 in forum Golf MK2 - 1984 - 1992
    Last Post: 19-04-2009, 06:03 PM
  3. Please Help Is it the camshaft?
    By voors in forum Golf MK4 - 1999 - 2004
    Last Post: 18-03-2009, 10:42 PM
  4. help 1.9 pd camshaft
    By jonathan bees in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-09-2008, 10:24 PM
  5. Camshaft need change - 2001 A4 TDI
    By tyberwan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-11-2007, 03:11 PM
