Thread: 2008 VW Passat 2.0 cr tdi, engine MIL light on Fault code P2563
  1. 2008 VW Passat 2.0 cr tdi, engine MIL light on Fault code P2563
    Sep 2009
    darlington
    Hi all, my 08 passat is showing up this code,im hoping this isnt a faulty turbo.Had a new egr valve and throttle body about 3 months ago.Anyone any ideas? thanks in advance
  2. Re: 2008 VW Passat 2.0 cr tdi, engine MIL light on Fault code P2563
    Nov 2009
    46 Post(s)
    http://wiki.ross-tech.com/wiki/index.php/009571/P2563
    Turbocharger Boost Control Position Sensor Circuit - Something to do with the turbo anyway
  3. Re: 2008 VW Passat 2.0 cr tdi, engine MIL light on Fault code P2563
    Norfolk
    Quote Originally Posted by BoyceyS4 View Post
    It's probably a turbo act uator fault. Generic P codes are not much use. You could do with a proper code read. Turbo actuator failure on these engines is fairly common.
  4. Re: 2008 VW Passat 2.0 cr tdi, engine MIL light on Fault code P2563
    Feb 2012
    Exeter UK
    It's probably a turbo actuator fault. Generic P codes are not much use. You could do with a proper code read. Turbo actuator failure on these engines is fairly common.
    Yes, the actuator diaphragm on my 58 reg tdi 140 Highline estate failed within a couple of months of buying the car. Fortunately from a VW Dealer, so cost was fully covered by the VW Warranty you get when buying a dealer approved vehicle. Car had only done a little over 40k mls!
  5. Re: 2008 VW Passat 2.0 cr tdi, engine MIL light on Fault code P2563
    Jun 2010
    gosport UK
    I had the same on my 58 plate 170 Tdi. Not impressed but once fixed i was getting better mpg etc. Or so the MFD said. Why oh why the actuator can't be replaced with out the need for the whole unit i don't know.
    Corsa - But want an Audi!!!
  6. Re: 2008 VW Passat 2.0 cr tdi, engine MIL light on Fault code P2563
    Jun 2007
    Up North
    Quote Originally Posted by bambamjj View Post
    I read some info, (don't know whether it was true) that said the adjustment of the actuator has to be set up to the turbo on an air flow rig when new or after a refurb, otherwise you risk over/under boost. Sounds like overkill to me, but that was the explanation for why you can't just change the actuator.
    All of the "how to" guides to guide you through a turbo strip and clean stress that you must not change the length of the adjuster.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  7. Re: 2008 VW Passat 2.0 cr tdi, engine MIL light on Fault code P2563
    108 Post(s)
    1816 Post(s)
    The actuator can be bought as a repair kit and as long as the instructions available on erWin are followed explicitly then it does not have to be set up on a flow bench.
  1. fault code v157 and engine management light on
    By pusstv in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-02-2015, 06:48 PM
  2. MIL fault code
    By MFGF in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-01-2012, 12:49 PM
  3. Fault code 18047 Passat tdi
    By Mark Redman in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 13-05-2010, 11:34 PM
  4. tdi ecu light and fault code questions
    By imortalmonkey in forum Golf MK4 - 1999 - 2004
    Last Post: 10-05-2009, 10:59 AM
  5. Golf 1.8T Fault Code (Engine Management Light On)
    By Silver1.8T in forum Golf MK4 - 1999 - 2004
    Last Post: 08-04-2008, 08:21 PM
