Thread: Looking for VAGCOM in Lancashire area
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 40
  1. Re: Looking for VAGCOM in Lancashire area
    #21
    May 2012
    Blackburn, Lancashire
    Sorry but leave Preston around 1.30 n home after that.
  2. Re: Looking for VAGCOM in Lancashire area
    #22
    Apr 2009
    Preston
    Il be in Preston that time or I can meet u at work at 6.30pm it's in between Preston and blackburn
    Y90USF
  3. Re: Looking for VAGCOM in Lancashire area
    #23
    May 2012
    Ok . I'll let you know
  4. Re: Looking for VAGCOM in Lancashire area
    #24
    Nov 2015
    Preston, Lancashire
    Looking for VAGCOM near Leyland/Chorley,
    Got an A7 and am interested in the tailgate closure from the key fob mod from the A7 forum
  5. Re: Looking for VAGCOM in Lancashire area
    #25
    Apr 2009
    Preston
    Hi pal my friend has currently borrowed the lead and is from Chorley. If you message me some details il ask him to do the mod for you.
    yousf
    Y90USF
  6. Re: Looking for VAGCOM in Lancashire area
    #26
    Nov 2015
    Preston, Lancashire
    I need to have 15 posts before I can message, does your buddy live or work in Chorley? I could meet up eve or weekend no problem
  7. Re: Looking for VAGCOM in Lancashire area
    #27
    Apr 2009
    Preston
    I will have a chat to him and get back to you.
    Y90USF
  8. Re: Looking for VAGCOM in Lancashire area
    #28
    Nov 2015
    Preston, Lancashire
    Looking for:
    Close your boot remotely using your key fob (and retain the opening feature)
    Go to Module 46 (cent convenience), coding, long coding helper and ensure byte two, bit two is ticked it says "Comfort operation: Remote control active". Then got to module 6D (Trunk Electrics), security access and enter security code "12345". Then still in Module 6D, click adaptation, channel and there are 4 options in there (among others) called "Activation using rear lid opening button in remote key - Touch function for closing". Select all four of those options, one at a time, and change the value to ACTIVE and press do it. Thats it. You still open your boot as normal - press and hold the middle button on the fob, but to close it, you can now just click the button on the remote (not a press and hold) and the boot will close and beep to warn you. Love this mod!
    Activate the needle sweep
    Go to Module 17 (Instruments), coding, long coding helper then in Byte 1 there is a tickable option. Tick the Guage test / Needle sweep box. Then Do It. Your needles will go all the way through their full range of movement when you start the engine (the markers for the cruise control light up and go off again too)
  9. Re: Looking for VAGCOM in Lancashire area
    #29
    Feb 2016
    Preston
    Hi, by anychance do you still have a vagcom? Im from the preston area requiring a search to see why my alarm keeps going off, (golf mk5 1.9tdi)
  10. Re: Looking for VAGCOM in Lancashire area
    #30
    Nov 2015
    Preston, Lancashire
    Sorry but no, I used a company called Hazzy Dayz to sort the coding for me, (they are down south) so it might be worth keep trying on the forum for some one more local.
  1. VagCom Can Stafford area
    By PirateDave in forum VCDS - Users Locations
    Last Post: 04-06-2012, 03:57 PM
  2. anyone with VAG COM in Lancashire area??
    By Y90USF in forum VCDS - Users Locations
    Last Post: 06-02-2011, 11:15 PM
  3. Vagcom Nottingham area
    By Drdremob in forum VCDS - Users Locations
    Last Post: 03-12-2010, 08:52 AM
  4. vagcom gwent area anyone?
    By minty0_10 in forum VCDS - Users Locations
    Last Post: 23-08-2009, 11:54 AM
  5. Vagcom (anyone Lancaster area)
    By ronmcintosh in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-01-2008, 11:26 PM
