Thread: Interior trim removal passat
  1. Interior trim removal passat
    May 2009
    Kendal
    2005 VW Passat 2.0 diesel estate
    Trying to remove the tailgate interior lining to find warner ingress to actual tailgate. I have removed 4 screws and managed to 'pop' off the lower part of the trim up to where it joins the window trim. Cannot see how to remove the trim which goes around the actual window interior. Please can anyone help?
  2. Re: Interior trim removal passat
    Jul 2012
    Crewe United Kingdom
    Same as lower one. They both fitted by the metal clips around.
  3. Re: Interior trim removal passat
    Aug 2012
    Gourock, Scotland
    I have a 1998 Passat TDi estate and the advice to remove the screws in the handle recesses does not help - as I can't find the screws! Do the old estates have a different method for removing the trim panel? I can pop out some of the clips and remove two screws from the join between the lower and upper parts of the trim but it feels like the lower part is held by something more than clips. Any advice?
    Charlie.
  4. Re: Interior trim removal passat
    Mar 2013
    Ireland
    Hi,Have you managed to remove the plastic trim around window on the boot door?
    If anyone knows how to remove that, pls help.
  1. A6 C6 Interior trim removal - Clipped or screwed?
    By skids63 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-06-2018, 09:34 AM
  2. Replies: 1
    Last Post: 09-08-2011, 09:22 PM
  3. drivers seat removal and interior trim
    By tgxlee in forum Touran - Sharan - Caravelle
    Last Post: 03-01-2009, 05:18 PM
  4. removal of interior trim
    By bonerpart1 in forum Golf Plus
    Last Post: 13-06-2008, 06:59 PM
  5. 2000 Passat Interior Trim
    By talleyca in forum Passat - Archive Topics
    Last Post: 26-05-2007, 06:51 PM
