Thread: A6/C6 injector PROBLEM - Replacement/refurbished injectors possible?
Page 1 of 16 12311 ... LastLast
Results 1 to 10 of 153
  1. A6/C6 injector PROBLEM - Replacement/refurbished injectors possible?
    May 2012
    Guildford
    I have a 3.0Tdi Quattro Avant (2005) and my Audi dealer tells me I need to replace all six injectors at something like £2000+
    Is this an easy job? Can injectors be refurbished?
    Anyone have any experience in this area as, apparently, diesel is slowly getting into my sump when the injectors deliver too much diesel into the pistons when I'm idling in heavy & slow moving traffic. Otherwise the car runs fine!! Any comments. guidance or help would be very appreciated??
  2. Re: A6/C6 injector PROBLEM - Replacement/refirbished injectors possible?
    Southern County Softy
    20 Post(s)
    http://www.dieselbob.co.uk/injectors.aspx
    Diesel Bob can test and repair injectors.
    You could try a local Bosch centre.
    A4 2.5 tdi QS (mapped)
  3. Re: A6/C6 injector PROBLEM - Replacement/refirbished injectors possible?
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by hotfire2009 View Post
    Are you able to give more info as how they diagnosis fault... eg had oil change and they find diesel mix (just trying to gain knowledge!)
    As how read your OP it seems like you are not experiencing smoke/rough idle making you feel they are faulty?
    Check this thread https://www.vwaudiforum.co.uk/forum/s...white+smoke+a6 page 2 post 17 can clean, no refurb/repair option
    there might be more info on VWAF, try search box...
    but I had seen this thread on another forum http://www.audi-sport.net/vb/a6-s6-a...ce-please.html a success story via ebay & secondhand injectors all for £700...
    Just to give you example below are part no for injectors used and when dropped because of issues/better manufacture etc for my A6 3.0 TDi Engine code BMK Injectors (currently mine are 059 130 277 S, must be orig.)
    059 130 277 S
    059 130 277 Q DROPPED 01/06/2005
    059 130 277 AA DROPPED 01/06/2006
    059 130 277 AB DROPPED 01/09/2006
    059 130 277 AH DROPPED 01/04/2009
    059 130 277 BD Current part since 09 (these apply to BMK BNG ASB engine codes)
    If you ease gently cover off engine (held on by 4 rubber socket/pins) part no is on the side of injectors, just below flare nut. I found using one of those dental mirror things allowed me to read/decipher as back to front in reflection!
    I would check on ebay (uk/germ.), why not try a local VAG specialist to fit? as long as you get genuine ones even main dealer would fit for you, but would check first as some are accommodating others are not...
  4. Re: A6/C6 injector PROBLEM - Replacement/refirbished injectors possible?
    May 2012
    Guildford
    Many thanks for the advice, info & other contacts - a lot to consider!! Phil
  5. Re: A6/C6 injector PROBLEM - Replacement/refirbished injectors possible?
    Sep 2011
    As I'm not sure which sponsor is close to you check in here https://www.vwaudiforum.co.uk/forum/f...-Site-Sponsors maybe second opinion help?? one time a main dealer say "your rear bump stops are perished advise change" I checked myself and yes rubber surface looking a little aged but no cracks/tears and still functional...
    Quote Originally Posted by gupsterg View Post
    As how read your OP it seems like you are not experiencing smoke/rough idle/faults making you feel they are faulty?
    Why I ask this is I have an issue with my car (not going to digress), I found a thread on German site which seem to suggest if injectors dribble then when starting car you would get uneven start-up/maybe rattle noise... do you get this
  6. Re: A6/C6 injector PROBLEM - Replacement/refirbished injectors possible?
    Jun 2009
    Bexleyheath, England
    Gup can you show this "Flare Nut" on a pic, as I aint got a clue where you mean
    George
    1998 A6 Avant 2.5TDI AFB
    RETIRED @ 185K miles,
    2006 A6 Avant 3.0TDI BMK S Line Quattro retired due to RTC
    2009 S4 B8 Avant Stage 2 + DP EPL & TCU, big list of mods
  7. Re: A6/C6 injector PROBLEM - Replacement/refirbished injectors possible?
    May 2012
    Guildford
    No, I'm getting heavy blue smoke when in very slow moving traffic - say for 3 to 5 minutes or when I start it in the morning and don't drive off immediately (bit like leaving choke on). It all clears it self after a quick acceleration. Car runs fine but I am told by Audi that too much diesl is being delivered into pistons which creates blue smoke AND, a big AND, and that some diesel is seeping through cylinders into the sump and increasing the oil level!!
  8. Re: A6/C6 injector PROBLEM - Replacement/refirbished injectors possible?
    Sep 2011
    Quote Originally Posted by joedredd View Post
    flare nuts, union nuts..... I'm going Nuts
    I've even started to resort to dentistry equipment on my car!!!
    Well I know oil level not drop or rise since last oil change, check nearly every week as I drool and polish engine cover occasionally seen smoky start in mornings but again it clears very quickly and I'm putting this down to outside temperature, car warming up, etc. Get grey/black spurt of exhaust smoke at beginning of hard acceleration from stand still@lights/junction (through JoeDredd & his contact network was able to get advise from another good member that all is ok)...
  9. Re: A6/C6 injector PROBLEM - Replacement/refirbished injectors possible?
    Oct 2010
    Berkshire, UK
    Pay £75 and get a Diesel Terraclean done before even looking at changing the injectors. Also, pouring out the fuel filter into a clear glass jar and checking for soot clinging to the sides is a good test for a pourous head or leaking injectors. A8 tech knows the procedure
    2 0 0
  10. Re: A6/C6 injector PROBLEM - Replacement/refirbished injectors possible?
    Sep 2011
    Quote Originally Posted by joshA6 View Post
    Good info, putting my mind also at ease about my early injectors... when done my fuel filter and pour out had no signs of contamination... had stamp of 2007 on it even though F.A.S.H and last was in 2010@60K
    Just to add to joshA6 good post, fuel filter easy to do at home, two clamps, retaining clip on valve, one nut/bolt... I filled new FF with clean diesel, ran fuel pump via VCDS, to elminate most air I could, easy start up
  1. Please Help Injector replacement
    By Y90USF in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-07-2011, 12:50 PM
  2. Question Replacement Injectors - 170PS diesel
    By garrad in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-04-2011, 08:16 PM
  3. Please Help Fuel Injector Replacement
    By Sigmond in forum Golf MK3 - 1993 - 1999
    Last Post: 14-01-2010, 09:31 PM
  4. Idle judder - injector replacement ?
    By cjboddy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-09-2009, 11:36 AM
  5. Injector replacement.....
    By djl78 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-03-2009, 10:35 PM
